Ahoy Mates
What type of joint should be used or types for 90 deg. corners of top railings along the hull . Would it be a butt joint or should you have a tongue or other type of interlocking shape?
Time period would be 1600-1750 English warships.
Thanks
Keith
My first thought was snarky- especially for the English shipwrights: Why do a simple butt joint when you can do a scarph?
Then thinking about it - the structure is subject to constant motion and stress in all 4 dimensions - though the effect of Time is much more gradual.  A straight butt joint would be difficult to fasten in a way that was not subject to early failure.
Quick research answer:  Not a butt joint or a scarph -  a third element : a lateral knee was worked in.   It spanned about 1/2 the width of the rail timbers, each arm would be long enough  to support a couple of horizontal trunnels into each rail segment and the inner surface would be an arc rather than an abrupt meeting of two planes.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
