P1000297.thumb.JPG.4d9add8df619e327ea61436ba9e0edf6.JPGa few photos of my progress been busy with other things! Have stuck mainly to the instructions as I am not great at kit bashing just enjoy the actual building even if its not very accurate,I think the flags look awful so may well leave them off when I reach that stage,
Edited by francisb
Looks like you are off to a good start. Yes, the lack of available pictures of this ship is frustrating. In addition to my own build here is a link to another good build of la Couronne on here. This is the Mantua version but is still a good guide as many of the elements of construction and of course the overall shape and design is the same.
http://modelshipworld.com/index.php/topic/1022-la-couronne-by-majq-mantua-198/
I have used it extensively for ideas on how to build and especially for decorative ideas.
One thing you may consider doing is replacing the kit supplied wood with better quality when you do your hull planking. What came in mine I used for the wales up and the decking but for the lower hull I used wood from Crown Timberyard ans I am very glad I did.
I will follow along and watch your progress as I am excited to see another Couronne being built. Good luck!! :D
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thanks E J will see about the hull planking nearer the time, One question if you don t mind I had to adjust the shape of the poop deck number 23 a fair bit more so than the main deck did you find this? all the best Francisb (Mark)
Mark, yes I had a lot of modifying to do to get that deck to fit. Below is a picture of how mine currently sits. In the first fittings I had to enlarge the forward openings and basically had to double the size of the aft ones as there was no way to make the precut ones fit. However, even after all that I finally decided that I did not like the way the ribs looked due to their huge size. The hull is not that thick to encompass them at that size and they are not supposed to show on deck so I cut them off. When I finally install this deck I will plank over the holes and add an interior plank along the hull to thicken the hull properly. I'm going to be cutting down a lot of the ribs where they come through as they are not the correct size to be part of the framing.
-E.J.
I see you have started your log! Good job so far, and good luck!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
  • 2 months later...
  • 7 months later...
Hi the wood is already stained this blue ,but you could make it with say Prussian blue with a touch of black I have used this colour on the roofs of the after and fore castles hope this is of use,will post some photos soon as have not put any on for ages!
Mine also came stained for me but thanks you for sharing that paint mixture to try out. I have been looking at different shades of blue to use for my S.R. build. I like the look of the stained wood that came in my Couronne build and was trying to think of how to match it. That will be worth giving a try!
Also, yes! Please update your log! I have been wondering how you were coming along on it and hoping you had not given up. Looking forward to those new pictures! :D
-E.J.
Hi as you can see I have stuck very much to the kit instructions so nothing very original or historically accurate! But it pleases me! At the moment I am struggling with  the masting ,not impressed with the plans and measurements given still will keep at it, will post some more pics later ,by the way have looked at your build log FANTASTIC!! Really like your tops ,you have great skills
looks very nice indeed good shew............one thing i can't figure out is the pin rails over the cannons in this kit......i thought all the lines would get in the way of the functioning of the guns........
Hi yes you are right,also with the channels either the shrouds would be in the way or the chain links would interfere with the gunport lids, there seems to be many contradictions in this kit ,struggling with this one even though I have built the Bounty and years ago the small Mantua Victory and the Panart Cutty Sark both of which my brother managed to sell for me!!Have been given the HMS Pegasus kit for my 65th! At least the instructions look good! best wishes from Mark
You are doing a great job! She is looking very nice and well built. Asfar as sticking to the kit design, there is nothing wrong with that. You will still have yourself a very nice model and can still be proud of your work.
As as to the placement of pintails, channels, chain plates, shrouds and rigging, no, the locations did not always make sense at least to us with a more knowledgeable perspective. However, during the early 17th century, large ship construction, especially for war ships, was still in its infancy. It would be another century before they really figure out the science behind it and begin to perfect the designs. At this particular time it is mostly guess work and trial and error. Emphasis on the error. We now have the advantage of looking at successful designs such as the Victory and Constitution but they were just building off what experience and knowledge that particular ship builder had. The mathematics were not yet formulated and there was no way to test out a design until it was built at which point you hoped it worked!
I have questioned many things about the design of the ship. So far what I have learned is that many things don't make sense. To make matters worse, there is very little historical information about her and the way she looked seems to vary greatly probably due in large part to refurbishing as her career went on. Dates and records have been lost to time.
Do do the best you can and ask questions. I can tell you what I have done so far. As to dimensions, most of mine I have taken from the 1:1 scale drawing that came with the kit. Then tweeked as needed! 😀
-E.J.
