I have seen this referenced as applied to forming eight-sided poles in configuring masts and spars.  Can someone explain this for me?
                                     Walt Haynes
Hi Walt;
This refers to the proportions to be used when creating an octagonal section from a square section.  You measure 7 units in from the corner,  along 2 adjacent faces,  then a further 10 units,  then a further 7.  This is then repeated on the remaining 2 sides.  Joining all the points at 7 units with lines to make triangles will result in an octagon.
Put another way,  any square timber should be divided along its faces into 24 units,  and then those units split as above.
When working with inches,  24 units is relatively easy to find.
All the best,
Mark P
Edited by Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
