Dont get it. The oppenings are 9mmx9mm. The disc is very big for that.... how did you did it? Did you cut the disc in a smaller diameter. I use the dremel drill. Meking a number of holes and then connecting them together and cleaning the h opening with files and sand paper
nirvana
Its not a stupid question you got there. The answer is that the dvd has detailed pictures and instructions where the mesuarments are given in various ways.  Extra to that there is a big coloured picture scale 1:1 ( showing every view of the ship) where you can actually mesuare everything.
I see. Ok its a way to do it. But you destroyed your nice planking. Anyway its not a bad idea.
I got lucky and found some plastic that matches the yellow just about perfectly. I really like the diecast pieces that AL provides for the bow railing.Just glue on some mahogany, flip it over ,drill a hole and run a square section needle file though it to make the square holes.
Not bad idea...
 Go ahead, wonder how the result is going to be. I think its going to be just fine.
That's right. Steps for crew to climb the hull from small boats to the upper deck.
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Good work, looks like you're having a blast.
Thats correct about the steps, they weren't common place until the later half of the 17th century and disappeared at the beginning of the early 19th century. Even then usually only found on larger ships.
With those types of items like the steps and the channels I like to use fine pins inserted through the piece leading into the hull. This will give it more 'teeth' it help keep it in place.
Anton T
Current build
This ship, now in real life, most likely will have students, etc. on board as part of the crew so the insurance company probably forced them to add the screening. Your earlier version (before the rebuild) only had real sailors on it, the insurance company didn't care so much about them!
