I subscribed to Woodsmith Tips and got a link to this and many other useful tips
http://www.woodsmithtips.com/2017/05/04/?autostart=true&utm_source=WoodsmithTips&utm_medium=email&utm_campaign=12478
Alan O'Neill
That seems like a good way.  Another common cause of incomplete curing is incomplete mixing.
There are couple of other ways.  You can buy small quantity tubes with a mixing nozzle, but they're a bit expensive.  I usually use a twinned resin/hardener syringe to get the proper ratio, and I squeeze it into a baggie and seal it and then mix it thoroughly.  Work the mixed epoxy into a corner of the baggie and then snip off the corner.  Use it like a baker's pastry bag.
