Greetings everyone;
Can anyone point me to a good source for the scantlings of the stern timbers in a 74 gun ship,  built in the first half of the 1780s.
I can find an entry in a contract I have which specifies that the counter timbers should be 10" sided,  but no other dimensions are given.  Goodwin,  rather frustratingly,  gives a range of fractions to multiply parts of the stern by to obtain other parts,  but he does not give a starting dimension to which I can apply these factors to begin the process.
The establishment lists do not mention them either,  as far as I can determine.
I could guess at them being the same as a toptimber,  or fourth futtock perhaps,  but that has no basis in fact.
All the best,
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
Are they in Scantlings of Royal Navy Hips by Allan Yedlinsky?
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Thanks Wayne;
They might be.  I don't have this book,  as I have (or thought I had) a complete list of scantlings for both the vessels I am currently working on.  Only realised there's a bit of a gap when I reached the stern timbers.
I have found everything I need in Steel's 'Vade Mecum',  of which I have a pdf copy I downloaded from the Bodleian Library in Oxford (which incidentally,  is a much better copy than Google's own one)
Although he is a bit later,  I think that his lists are based on earlier practices,  and I can use his scantlings for a 74's stern without worry.
All the best,
Mark P
The following is a page from Scantlings of Royal Navy Ships that may help.  I assume you were speaking of the counter timbers. Note that the Shipbuilder's Repository (1788) does not have all the dimensions Steel shows.
Thanks for the plug Wayne.
Allan
Thanks Allan;
Looks like a useful book.  I shall have to get a copy.
All the best,
Mark P
