First, Administrators, if this is the wrong forum, sorry.
I am building the ME Confederacy. The main wales are painted and I am getting ready to paint the area above the channel wales. The gun ports appear to be reasonably shaped and positioned when viewed from the outside.
Now comes my problem. I remembered testing the stern chasers on the Syren to make sure they would be positioned in the ports correctly. I tried the same technique on the Confederacy and with the decking laid down the guns will not sufficiently clear the port sills. I built a kit gun carriage using the after market brass cannon and that has even less clearance.
Short of blowing the project up (I won't do that anyway) I seem to have a choice of lowering the sills or laying a second false deck to raise the final deck level. I don't know if that would throw the quarterdeck and focsle off.
I would appreciate any advice or suggestions that you can offer.
Thanks, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
If I understand correctly , I would think you would be better off building a couple of taller gun carriages.
Edited by michaelpsutton2
Drown you may, but go you must and your reward shall be a man's pay or a hero's grave
Hi
well I did have the same problem but I did by guns and carriages from syren
and ........ it diddent work, the New gun carriages was a bit to large for the gun ports wat I did was using the kit provideo carriages and syrens guns
it works well for me
Svein.erik
