You may be aware of the battery powered dremel. If not, here is some info and a few pics of the one I purchased a few days ago.
Model 7300 (Newest)
Two speds Low 6,500  RPM  High 13,000 PM
Comes with one 1/8" collet, Set available with 4 collets 1/32, 3/32, 1/16, and 1/8 as an accessory
Charger  (3 hour charge time)
9.2 ounces
6 1/2 long without drill bit or other accessory
Cost $45 at Home Depot   (Canada....less everywhere else in the world I'm sure.)
Accessory |Collets $13
Runs true and smooth with 0.60mm drill bit at both speeds chucked into 1/32 collet. Fits
hand well and is used as a pencil. Unit is well balanced. Most inportant.....unit is high tourque. Drills and sands without bogging down. Purchaced because I wanted a small but powerful unit without a cord. Don't know the run time.
006.jpg?t=1366808905
Rests on flat bottom..Watch your eyes!
004.jpg?t=1366808923
BFN,
Hopeful aka David
Edited by hopeful
David
    I was looking for one of those about 2 weeks ago at my local Home Depot.....they did not carry them there..said sales were not enough to keep in stock.
Guess will have to go online to find one.
Is it working out okay?
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Colleagues, prompt, please, as at this small Dremel affairs with vibration when drilling are?
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Hi, Hopeful aka David, thanks for your "two cents" !  :)
Best regards,
Garward
I don't know it that is what they are saying or not, but in my opinion it would only be for small holes due to torque limitations and battery life.
As far as repairing your corded dremel if you are confident you can replace high speed bearings, I would go for it...but it seems the tolorence will be very close with little room for error.
Me, if the cost of repair is 50% or higher the cost of replacement...I just buy another.... :)
SEE YA LATER
Never noticed any problems with mine... seems to have all the power and torque of the full size. No trouble cutting through nickel silver model rails with a cutoff disc. And being smaller it's quite a bit easier to control...
Andy
Quando Omni Flunkus, Moritati
USF Confederacy
