Bill,
Congratulations on getting out of the hull.  When I built my Bowdoin I didn't think I would ever get the hull buttoned up.  I learned about MH Ready Patch from Charlie at Bluejacket and found it to be a great filler although I'm not sure how it would do under water.
Steve
Steve,
Thanks-- I'll check that Ready Patch product out.   For me, water exposure is not really a concern, as the hull will be getting a layer of fiberglass, sealing everything in.....
In progress:
BlueJacket Lobster Smack 1/8 scale (RC)
1/96 Revenue Cutter Harriet Lane RC scratchbuild
completed:
1/144 scale USS Guadalcanal CVE-60 RC scratchbuild
Revell 1/305 USCG 327’ Secretary class cutter
Dumas 1/16 scale USCG Motor Lifeboat 36500 (RC)
Lindberg 1/95 USCG Lightship LV-112 “Nantucket” RC conversion
No photos today-  but I have made great progress this weekend sanding and filling the hull.
Steve- thanks for that tip on the MH Ready Patch- that stuff is great!
 I applied it with a nylon putty knife, almost like a thin-as-can-be skim coat on a plaster wall.  I then used my electric 1/4 sheet power sander to sand most of it away, leaving the gaps and valleys filled.
I still have a bit of work to do, to prep the hull for the next major step- the layer of fiberglass.
Edited by Rcboater Bill
Fixed typos
In progress:
completed:
Haven’t accomplished a lot, but here’s a shot of the hull after two rounds of filler and sanding. I’ve just applied the third (and final, hopefully) light coat of filler to a few spots that needed a bit more.   Next will be a final sanding to prep the hull for the fiberglass...
In progress:
completed:
  • 2 months later...
Finally got some time to focus on the model-   Applied 2 oz. fiberglass cloth on the starboard side.  After the epoxy cured for about 90 minutes, I went back and trimmed the excess with a sharp knife.
Will let it cure this week, and then hopefully do the port side next weekend...
In progress:
completed:
Finally got the starboard side of the sailboat fiberglassed. (Portside was done back in  early November.).  I may not get much more done until spring-  next step is a thorough sanding, which means resin dust, which means it will need to be done outside.  Winter in New Hampshire is not  generally a good time for that sort of outside activity!
In progress:
completed:
  • 11 months later...
This update is to let folks know the project has not been abandoned-  it just spent a year on the back burner!
It has been about a year since my last update, but I have done a little bit of work on the model over the summer....
After fiberglassing the hull, I had several rounds of sanding, filling imperfections, sanding, filling, sanding, etc. etc.   Finally, in late fall I sprayed a coat of Duplicolor fast fill primer on the hull.  Then I screwed up....
I left the hull in the garage, thinking I’d do one more outdoor sanding session before winter settled in, but never got around to it.    Today I thought, “I should bring the hull inside- being exposed to freezing temps may not be good for the hull.” (We had already had several days with temps in the low 20s, or -5 C.)  Turns out I was right - the hull has a couple of cracks in the finish.
My main reason for the lack of progress was that I focused my efforts this year on finishing my 1/144 scale USN Escort Carrier- the USS Guadalcanal, CVE-60.   I finished the model’s air wing  in October, and had a couple of nice sailing sessions in this fall....
added photos
In progress:
completed:
  • 6 months later...
I still haven’t abandoned the build, but it on the back burner.  A big reason for the delay is I’m in a quandry- I’m not sure how I should  complete the model.
I set out to build it as an RC boat, but I’m having second thoughts, for two reasons:
1. The boat isn’t really seaworthy if built to scale. It has that huge cockpit which is open to the bilges.  Put the lee rail under in a gust, and she’s swamped (or worse!).  A clubmate built one of these kits as a sailing model, but he planked over the cockpit, sealing the hull. His model sails safely, but gives up a lot of realism on the display stand…
2.  In order to make it a sailing model, you need to make an extended sailing keel with a lead bulb for stability and ballast.  That means making a big lead bulb, which I find a little intimidating.  Plus, lead shot is very hard to get these days.
I can’t go much further on the build without making up my mind…..
In progress:
completed:
Nic,
That’s a great idea- thanks!
In progress:
completed:
  • 5 months later...
