HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
1:135 H.M.S. Bounty
Amati ‘First Step’ series
Catalogue # 600/04
Available from Amati
HMS Bounty, also known as HM Armed Vessel Bounty, was a small merchant vessel that the Royal Navy purchased for a botanical mission. The ship was sent to the Pacific Ocean under the command of William Bligh to acquire breadfruit plants and transport them to British possessions in the West Indies. That mission was never completed due to a mutiny led by acting lieutenant Fletcher Christian. This incident is now popularly known as the mutiny on the Bounty. The mutineers later burned Bounty while she was moored at Pitcairn Island. An American adventurer rediscovered the remains of the Bounty in 1957 and various parts of it have been salvaged since then.
Extract from Wikipedia
The kit
This is the second of the three Amati ‘First Step’kits that I have for review here on Model Ship World. As with the previous review of their Santa Maria, also in this range, this kit is aimed at the newcomer to this hobby, who want to see a fair and decent result without having to be hands-on with all of the various skills needed and tools required by a more complex kit.
The kit is packed into an attractive and glossy box which isn’t too large and certainly won’t dominate your workbench. A photo of the completed model adorns the box-art, showing you that the results from such a simple kit are actually very pleasing and certainly not shabby at all! Note also the dimensions of the finished model are 26cm in length, 28cm in height, with an overall width of 6cm (although according to plans, that last measurement is actually 9.6cm at the widest yardarm). Opening the box, you’ll note that the modeller isn’t inundated with a mindboggling array of materials, but instead things are kept nice and simple, with a small bundle of timber, pre-shaped hull halves, small packet of sheet material, flags, fittings box, manual and single plan sheet.
As noted, the hull in this model is solid, and provided as halves, as per the Santa Maria. In fact, the parts themselves appear to be a standard, and identical to the previous kit, and indeed to the review which will later follow this one. These parts are nicely carved and shaped, with just a sanding and sealing needed to finish them before painting. Internally, you’ll note the two holes which appear on each half. These are to fix the dowels to which locate the parts together, with the false keel being sandwiched in between them.
That false keel is made from MDF and included on a laser-cut sheet with a number of other parts for the quarterlight windows and transom sections. Quality is excellent but remember to wear a mask if you need to sand any MDF at any time.
A thin, laser-cut ply sheet is included, being the last of the sheets of parts in this kit. Here you will find parts for the bow timbers, transom windows, quarterlight windows and the mast tops. Being laser-cut some parts may need any char removing from the edges before use.
As with all First Step kits, this includes a wooden plinth onto which your model will mount. Turned walnut pedestals are also included.
A small bundle of both strip and dowel is included. Strip looks like Lime, and the dowel is Ramin. Quality is very good, as you expect from Amati, with clean cutting and an even appearance.
Printed paper is included for the flags. These are designed to be folded around the rigging lines, providing a face on each side. You will need to manipulate these so that they hang naturally. A large piece of off-white sail cloth is also included too. You will need to use the templates on the main plan sheet and transfer the shapes to the fabric before you add any boltrope and stitching.
As with all Amati kits, the familiar plastic fittings box is included. This compartmentalised box contains parts for the windlass etc., plastic moulded grating, rigging cord, turned walnut pedestals, set of two anchors, nails, cast ships launch windows, lanterns and figurehead, eyelets, rings and some rather attractive cast cannon which look amazing despite their tiny scale.
A large, single sheet plan is included, printed on both sides. The first side shows the ship in plan and side elevations, as a complete masted and rigged vessel, with locations for the various deck fittings etc., plus a set of templates for the ten sails that need to be made if you wish to have your model adorned with them. On the reverse, there are masting illustrations, and rigging drawings. These look very straightforward to follow and shouldn’t present any problems to a novice.
Bounty’s instruction manual is a 10-page affair, printed in black and white with the model broken down into 16 constructional sequences. All are accompanied with English text and annotation, with the drawings themselves being very easy to follow. Painting references are provided throughout. The last page of the manual includes a parts list that you can use to check off against the kit to ensure there’s nothing missing.
Conclusion
Another great little introductory model from Amati, designed to ensure a trouble-free move across into this great hobby, and without compromising on the finished result. Everything us here that you need, apart from paint and glue. This would also make a nice project for a seasoned modeller who perhaps just wants a little side project for a friend etc. Either way, it’s a very worthwhile kit that is certainly worthy of your consideration.
My sincere thanks to Amati for the sample reviewed here. To purchase, click the link at the top of this article.
Ongoing:
