made a mistake, put away a lot of  area balcony:
the perimeter of the balcony <> perimeter railing
way to fix on the photo
Попков Сергей Федорович
Two evenings cooking  the end mills. Turned out one of the three necessary.
The end mills produced relief strips rubbing strake
Edited by PSF
Continued production of the end mill
strips  rubbing strake from blackened hornbeam
set improved  decoration
Edited by PSF
  • 2 months later...
The crossbar window is made of yellow wood. Glass from plastic from a floppy disk. The  transom stern of blackened wood - hornbeam
установлены перила верхнего балкона
Hi Sergey!
When you improved the windows, is it difficult to not break off the little carvings?
Certainly hard!
With the help of Bor-machine  (see photo)  and burs for jewelers
Of course, in one place of  part broken. I glued it on the glue is already in place
but if done carefully and cautiously, then happen without failure
installation hobnail into the side of the ship
hobnail from brass wire
1. marking zones position for  a hobnail from brass wire
2.made the tool  installation for  the  hobnail from brass wire
3. To complete the installation the  hobnail from brass wire has spent 2 weeks 3 hours per day
Hello Sergey,
Welcome back.
That is some progress you've made. Beautiful work.
I must admit, seeing your Le Mirage hanging in the doorway, was a bit scary.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
As always, the first test, and then ...
The following photos are only the test
These parts are not installed on the adhesive
It's time sets the anchors. This requires the marine rope. So I need to install on mechanism of winding marine rope (а) electric motor
Here's what happened:
Preparation for the production of the cheeks. Material pink pear.
