Hi, i have just started to build the above mentioned kit. I have fitted the frames to the keel and shaped the bow and transom and fitted the deck. Looking ahead there seems to be a problem, I aligned the deck perfectly centered but this leaves the deck quite a big hangover the frames so the planking will be under the deck. What I would like to know is if anyone out there has built this kit and do I sand the deck to meet the frames.
There's quite a few in the Kit area.  If you go to the link belowand select "wooden ship kits",  you'll get a PDF of all the wooden ship kits.  Just open it and got to the Bounty and the Constructo logs will be listed.   If you're going to open a build log, do it in the kit area also.
