Hi friends,
I have finaly decided to build Gokstad viking ship because I always wanted to build viking ship. Basic info about the ship can be foun here: https://en.wikipedia.org/wiki/Gokstad_ship
I used beautiful paper model kit from poland publisher WAK in 1:72 scale as a base for the build and upscaled it to 1:48 scale.
Original build of the kit from its designer loks like this:
Kit is used basicly as a plan. I am altering thickness of the parts according actual ship. I will be sanding some parts and repainting the whole ship (since I will modify the kit I do not know if I choose right forum category to start the thread, hopefuly yes). Main source of information is this book - Das Gokstadschiff und seine Boote by Werner Dammann . It is full of information about the ship construction including thickness and type of used material.
Here are some preliminary tests to find suitable colours.
Frame went together nicely according the instructions:
20200326144419-363724.jpg.9d1dcd946d1bfb7b51ca2c6a4ecd8573.jpgfile2.jpg.4193b168e1e24c81fbc3e97918376ce4.jpg20200327002441-363786.jpg.df625d8d2dd24f4281aff9d7d5f52938.jpg
I am painting each plank white, separately. Brush strokes are also part of the proces to make the effect of wood texture.  I do the carvings on the plank. Then the plank is attached to the hull.
20200501002743-366347.jpg.78be30f2ad20f0e95048455b39db9f18.jpgfile3.jpg.b579788e4d012a504576648ae2b0c80f.jpg20200501002741-366346.jpg.b358637c19cd2c08fe236c3bfa914b6b.jpg
I reached control point with my planking and I am way off at the stern and stem. After the searching why this happend I figured that the keel becomes longer because I use water based glue to make him and the paper stretched.
I will have to start over because I also want to change the planking itself to be more precise.
