I have just placed my order for a Duesk1:72 scale model kit NINA , while i am waiting for it to arrive my thoughts turned to barrel making so i did a quick forum search and nothing came up,My  question is how do you guys go about making ships barrels,
from one piece (turned on the lathe ) or by coopering.
(Pete)
Pete,
At 1:72 scale I think your best bet is to turn them up from solid.
Have a look at thread http://modelshipworld.com/index.php?/topic/1941-hints-on-painting-rings-on-barrels/?hl=barrel%2A which might give you some help to you. It starts with a question on how to paint the hoops on molded casks. It develops into the recommendation to remove the molded hoops then how to replace them with nearer to scale hoops. You could turn up the basic cask, score the plank lines then use the thread info to detail the cask.
There is also a useful thread on cask sizes at http://modelshipworld.com/index.php?/topic/138-re-post-of-info-on-barrelcasks-sizes/?hl=barrel%2A (barrel being a specific measure when it's not part of a cannon! :) ).
Edited by ianmajor
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Pete,
Ian M.
Thank you for the link(T http://modelshipworl.) very useful info,I will give this some thought and see what i come up with.
(Pete)
Here's the instructions I've played with.. http://arsenal-modelist.com/index.php?page=accessories   Down near the bottom.  But then again, I'm building a French ship....  :)
(Pete)
Hello Pete;
I think that there would be an answer to your question at the link below, at the post number 105 of "Le Bonhomme Richard by Jeronimo" at Scratch Build Log. There is a fantastic job... (But just barrel not gun barrel...)
http://modelshipworld.com/index.php?/topic/300-le-bonhomme-richard-by-jeronimo/page-7
Post #105
Edited by ashiponthehorizon
Best Regards…
Ferit KUTLU
Under construction: Frigate Berlin (Brandenburg Navy)
Hope: Frigate Wappen Von Hamburg (Brandenburg Navy)
Hello Pete;
Post #105
Many thanks for the link, lots of wonderful modeling skills in that build ,all i need now is some barrel measurements ,are there any charts giveing sizes in feet & inches or do i have to go to the local brewery with a tape measure. :)
(Pete)
Pete,
Some dimensions supplied by Andrew Baines (Curator of HMS Victory) in one of the other posts were as follows:
The dimensions given in the order diameter at the head, diameter at the bilge, height.
Barrel ---- 1' 9" ---- 2' 1" ---- 2’ 7”
Hogshead ---- 1’ 11” ---- 2’ 4” ---- 3’ 0”
Puncheon ---- 2’ 1” ---- 2’ 4” ---- 3’ 5”
All were circular in section.
Edited by ianmajor
Ian M.
