I see some of the ships featured here have scale planks, just a couple of questions I'm sure someone can fill me in.
When scale planking do you construct the hull with double planks?
Can you plank the first layer with strips that run the entire length from bow to stern, then scale plank the second layer?
Never had a lot to do with scale planks before and I'm pondering with the idea for a future build.
Regards, Scott
Completed builds:
Awaiting construction:
Scale planking can be done over solid, POB, or POF hulls. The first layer of double planking on many POBs is to provide a continuous foundation for the second. For the first layer, you can use full length strips or multiple pieces per strake. On my current build, I used some full length, but generally used two or three so I wouldn't have to deal with gluing long (typically 17-18") pieces.
Brian
"Give you joy!"
Current Build: RATTLESNAKE 1:64 POB (Mamoli)
Kits on hand: "Lexington", Mamoli: "Robert E. Lee", Scientific
Scratch to do: "Fannie Dugan", 1870s Sidewheeler Steamboat
Scott,
You only need to double plank if you're planking over a POB hull.  If it's framed then the scale planks have plenty of support.
John
Cheers guys, once again this site is tops for getting those questions answered. Thanks
Regards, Scott
Completed builds:
