As a beginner modeller, I have been struggled with hull planking. One of my main issues was shaping a clear and sharp planking line like in the above picture.
santa308.jpg.8cbd162f9a606cf2894da9731a20dc37.jpgsanta307.jpg.8061b0f9838637a8e39f58bd44237bdf.jpg
When I built a deck planking, I found that kits from some manufacturers or decades old kits had poor quality strips that had different wide. It is the main reason that the deck planking becomes ugly.
Before I began a project, I selected same width and same color strips from a kit. Sanding paper or miniature plane were also good solutions to adjust the width of strips. The result was great, and I had no dissatisfaction with the deck planking.
However, the 'curved' strips gave me a headache.
k85.jpg.3f5033758d6ce2c5161ae4d2ceccd208.jpgk86.jpg.b49c6c5d4259d462c67e0e0a8bc4f007.jpg
I read some instructions and tried tools such as French curves, but they were time consuming or not effective in my opinion.
I would say that I finally found a solution to the curved edge after years of contemplation.
It is a very simple method.
I used 3mm line tape. ( 1/8 inch whiteboard tape? ) The tape is thicker than the Tamiya or 3M 244 masking tape. I would say that 5mm or 1/4 inch wide tape isn't good for making a curved line, and 2mm or 1/16 inch tape is too narrow for this job. In addition, dark colors such as red or blue are better than lighter colors such as white and yellow.
I attached the second plank strip. I used water and a digital temperature controlled leatherwork iron.
This method consumes lots of line tape, but saves more time.
I didn't push the blade hard. A weaker force made me control well against the wood grain.
It was quite fun and fast to compare with my old process. Of course, the result was exceptional. I found almost no gaps between the planks.
I use the same technique on the other models, such as the water slide decal on plastic kits. There should be a ton of ways to use masking tape beyond my imagination. ;)
I think this is a very good idea to transfer the curve of a plank to another one, sort of a parallel marking out tool that boat-builders use for the same purpose. I'll have keep that in mind for my next project, where I will have to handle 2 mm wide planks.
