I just bought an airbrush compressor that sits on a 3-liter air tank.  It has an air/water filter at the pressure gauge.  Should I also use one at the airbrush end of the hose?
thanks
Richard
Richard
Member: The Nautical Research Guild
Enamel paints use organic solvents that are not misable with water.    If you are spraying enamel paint,  the condensed water vapor that increased pressure produced would probably make a mess of your paint application.
The most common class of model paint now is acrylic  which uses water as a solvent.  A slug of water may dilute pigment concentration,  but it may be easier to just  direct the nozzle to a piece of scrap cardboard until the water clears - if it appears.  The existing trap would probably cover you anyway.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
