Dear friends!
In a distant future, far, far away, I hope to have much more time for modelbuilding :)
Hence I have now (among other kits) bought Billings "Calypso"-kit.
It looks very nice I must say, very much so compared to the Billings-kits I built early 80s.
This one has a ABS-hull though. A first one for me.
What might be the best way to cut away the excess ABS plastic?
Simply scoring with a sharp knife a few tines, and then breaking of the excess plastic, piece by piece?
Thats what I do with styrene sheets anyway. Any other tips, hints or tricks? The ABS is rather thick in this case...
Kind regards, Pontus
Finishing Titanic 1/350 scale from Minicraft, Plastic. Partly scratch. Loads of PhotoEtch.
Upcoming builds: Syren from MS 1:64, Pegasus from Victory Models 1:64, Surprise from AL 1:48
Thank you!
That might be true. I read somewhere though that it might melt instead the plastic.
I guess i will try though.
With bodys for bigger RC-cars I happen to know they score the surface and then simply break off the excess plastic,
thats why I was curious if that technique could be used fot such hulls also (it is not the same material though).
Cheers!
Whether plastics melt during mechanically working them depends on how much energy you put into them over what interface - or in simple terms: when you run the cutting tool too fast, you are putting too much energy into the cut ...
