Good morning all,
I want to share with you an alternative nice way for caulking the deck of your model ship. I used this technique for the Fifie as you can read by the thread title, but I think the best use case would be for modern era Yacht or similar. I chose this technique because this type of sealant (used in real ships) helps sealing the whole deck as this is an RC model. Precautions is never enough eheh 😁...
In any case, I hope it will be useful for people out there building big scale yachts, modern ship or just want to try a new technique
Here is the link to the full video. https://www.youtube.com/watch?v=CybjsdaI1J8
YouTuber and Blogger talking about the world of model ship making.
You might also know me as Tagliamare
Looks great and watched and commented on your video!! I doubt that I would do that with the actual Amati Fifie kit, not your scratch built version as that supplied deck planking is only about a very thin 1.5mm thick
Hi David! Replied to your comment :)  personally I think it would work anyway… it’s worth a try
Carlo - you are probably right but being a wuss, probably wouldn't with the deck material being less then ..060" thick (many Americans don't fully understand metric measurement!). Then, my single history with Sikaflex sealant is that I ended up with about as much on me as my caravan's window replacement job. I have enjoyed that scratch FIFIE build and hope my R/C kit turns out decent even with the MDF bulkheads.
Did you already open a topic on your build? I would love to follow your work :)
Carlo, my model build is going very slowly plus being the first after many years of other free time eaters  have not felt that opening a build log is a positive  I'll drop some photos in a thread later.
Quite messy but I have to admit it turned out a lot better than I expected. The caulking does look a little wide to me but that is easily sorted by thinner pins. Another deck caulking option for us all to consider.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi all. I decided to install an autonomous pump in the Fifie.
I didn't want to risk to loose all those precious hours of work, so I thought I could invest some time on this. I programmed an arduino system that activates a pump whenever it detects water inside.
I leave you the video with all the details below
https://youtu.be/LnepjXmAfVc
Edited by carlo_l
  • 7 months later...
Ciao Guys,
I'm thrilled to share with you the completion of my latest project, a scratch-built RC model of the FIFIE, a traditional herring drifter from Scotland.
Embarking on this journey, my primary goal was to seamlessly incorporate all the intricate details of a static model into a functional RC vessel.
As you peruse the images I've attached, you'll notice the clean and crisp design that I've strived to maintain throughout the build. However, keen-eyed observers may spot a couple of missing elements, namely the lifeboat and the pump.
A lifeboat is nearing completion and will soon find its rightful place aboard the vessel, adding that extra touch of authenticity. As for the pump, it's still in the works. I'll let inspiration guide me in the coming days – after all, a bit of inspiration goes a long way in elevating the quality of our creations, wouldn't you agree? 😃
I invite you to share your thoughts and suggestions as I continue refining this labor of love. Let's keep the winds of creativity blowing and the waves of craftsmanship rolling!
Fair winds and following seas,
Carlo
