Does anyone have any advice on how to fit these onto normal CA glue bottles? I tried the other day and it worked ok until the damn thing popped off and nearly dumped a good chunk of CA on my boat deck.
Casey
"I drank what?" - Socrates
Current Builds:
Finished Builds:
Future Builds:
  • Mamoli Golden Hind
  • Mamoli Black Prince
  • AL Swift
Hi cdogg
I assume you mean the Zap extenders.I use these all the time and have found that they only fit properly on Zap bottles.When I get a new bottle of glue I fit one straight away and discard the top.It is vital that the extender goes all the way down to the little collar or it will pop off.They are extremely tight which is why its not a good idea to try and fit one to a part used bottle with a scruffy top.The glue never goes off as the tip seals right at the end with remaining glue.I simple cut 2mm off the end to remove the dried glue.When the tip gets too short as you get down the widening part I replace the tip.
Kind Regards Nigel
Currently working on Royal Caroline
Nigel, after applying the CA set the bottle upright, squeeze it enough to express the air out and clean the the extender, it won't get clogged near as often and will extend the life of the extender quite nicely.
Tom
I bought a bag of both extenders and replacement tips.  Here are generic photos;  I am trying to get these two to work but they are not the same brand but look the same.
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Thanks for the feedback Nigel, I added the pictures to show the two types of applicators I am dealing with.
@Tom, I read that soaking the extender tip in Acetone with clear it up?  True or better trimming it or throwing away?
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Casey
as an American living in the 21st Century I don't like waiting on anything....I stand in front of the microwave yelling "hurry up",  :angry:  so I don't like "soaking " anything for a period of time, except for planks as needed on bluff bows.
I try to avoid the need to clean the extender by applying a little preventive maintenance and clearing the extender with air as described.  However when I get a little lax and forget, then I chop off an 1/8th on an inch or so and move on.
Tom
I have been able to make these extenders fit by using a lighter and reshaping them.  All they are is teflon tubing.
David B
Edited by dgbot
Thanks Tom I will try that technique.Only thing is the sealed end stops the glue going off in the bottle.Maybe keep it clear while working and leave it blocked when I stop work for any length of time.As regards the tips in the pictures I can't really say as I only use Zap cyano.I did once try and fit a Zap extender onto a different makers bottle and nearly had the big spill you mention.
Kind Regards Nigel
I swear by these to apply my CA. I dont attach them to the bottle instad I put some CA on wax paper syphon a little up and apply to my work. If its wood it will draw it out of the tip, other materials I blow gently into the opposite end. My wife says I look like a crack head doing this but it works great and I dont get CA everwhere just where its needed.
Eric
Current build(s) ;
AL San Francisco II
http://modelshipworld.com/index.php?/topic/862-san-francisco-2-by-eric-al-190-sport29652/
MS Rattlesnake
http://modelshipworld.com/index.php?/topic/868-rattlesnake-by-eric-model-shipways-164-sport29652/page-2
Sitting on the shelf : MS Constitution, MS Sultana,
Wish List : MS Essex, Confederacy, and Syren, and a Victory kit by someone ?
"80% of the time it works every time."
Sport, that's a great technique! Thanks!
Casey
Current Builds:
Finished Builds:
Future Builds:
  • AL Swift
Yes. Acetone will dissolve all traces of dried CA. It takes sometime. So I just let my parts to be cleaned in a tightly capped glass jar when I go to sleep. Next morning they are pristine clean and I don't feel "I had to wait" any length of time. ;)
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
