After finishing my OcCre Polaris I wanted to go more advanced and chose the Beagle for my next model. I really like the look and also the historical background of Charles Darwin.
There she is:
Kiel is perfectly straight:
doing the skelleton
applied the deck before planking. I can fix it with some nails this way.
cabin walls added, thats it for the start:
On 12/3/2023 at 3:37 PM, NoelSmith said:
Nice start. Those clips look good for keeping the main hull form parts square.
Yes works perfect with them
Long time no see, but had a little bit progress on the Beagle the last weeks:
Started with the lifeboats besides planking the deck:
planked the deck with 6 cm long pieces, not single stripes:
added the brass doors and windows:
and already started with planking the first layer of the hull:
On 12/16/2023 at 11:03 AM, NoelSmith said:
Looks like you are making good progress on the Occre Beagle.
I see you have built the Occre Polaris and the Bounty's boat. What is your impression of Occre's kits you have built?
quality is good but the Models are not perfectly historical correct. Instrucions are clear and material is good. Good beginner models.
Finished the first and biggest one of the four dinghys:
not a lot of progress lately
3 hours ago, JFMJr said:
Started my Beagle a couple weeks ago. Just starting the second planking level. Gonna follow your build.. can use all the help I can get!
Looking good!
Hi, I missed your start a little, but I will join from now on your build.
I noticed that occre did some changes lately. It seems that your keel is made of presswood instead of the plywood I received in the kit I purchased a year ago. Quick question:
Are your blocks made of boxwood or are they plastic? Also, do you still have a sheet of walnut pieces?
Good luck with the rest,
Patrick B
Patrick B
blocks are made of Wood and yes I have a sheet of walnut pieces
On 1/12/2024 at 1:33 PM, Boerscht said:
Looking good!
Thanks! Just finished and sealed the hull.  Painting next  Do you plank the lifeboats with the same wood as the ship?
Patrick B
Sorry, Just saw this.. still new to using this site. Was this question for me? There is no plastic parts in my kit that I remember. Keel was not plywood. Still new to the terminology. lol
More dinghy work is done.
Now all the 4 are ready, took me quite some time…
Yeah i am now finally done with the second planking. Was pretty straight forward, just the rear and bow were a bit tricky.
Added the kiel parts also
Did some work on the inner side of the bulwarks with the decorstion strips and shapes
and prepared the canon hole parts and some deckings
next up is finishing the hull with decorstion strips and paint it
A lot of work went down last weeks.
Painted the hull.
Installed the rudder and rear decorations.
Steering wheel is in place and a lot more small details on the hull.
And here we go with another week of work on the Beagle:
Started with the deck fittings and did the deadeyes
the Beagle found it’s place
