On 10/29/2024 at 12:35 PM, Plankowner 54 said:
Very nice job.  I am a plankowner of the CDW.  Served 4 years on her.  Was aboard when we homeport shifted to Yokosuka, Japan.   I served as master helmsman, small boat coxswain, UNREP specialist,  and PHALANX CIWS ammo handler.  Steel hammer.
I really appreciate the kind words and thank you for your service! With your memory of her, I hope I did her proud.
  • 6 months later...
On 2024/1/2 at AM5点37分, ddp said:
看看这个。
在与 Keith Bender 的交谈中(请留意 Keith 在 2024 年初对该模型的建造评测!),他指出舵的间距太大。Keith 曾说过:“实际上,舵的间距是 20 英尺,轴的间距是 26.26 英尺。制造商将舵的间距设计为 25 英尺,轴的间距设计为 32.66 英尺。” Keith 随后补充道:“我保留它们的原样,因为大多数人不会察觉或注意到其中的差别。”
http://www.modelwarships.com/reviews/ships/ddg/ddg-54/ILoveKitCurtisWilbur/ILK62007.htm
Hi, I have been looking for Burke's Line chart. Can you tell me where to buy it? Or I would like to exchange my own Burke GA PDF. Thank you very much.
16 hours ago, ddp said:
“折线图”是什么意思
lines plan     I might have written it wrong.    (Do you have any other drawings besides this one? I just want to know if I can get more information. Thank you.)
here is some more. if you want larger versions of the drawings i had posted as site might limit posted file size then i need your email address so i can send them to you.
Thank you very much!    zhey392@gmail.com
Edited by DO335
