Topgallant Storm Rig
Go to solution Solved by popeye2sea,
I have not seen anything like this rig. I found it in NRG #28 pg. 84. As I have been trying to learn about rigging, I have read a LOT of books on the subject. I do not recall if it was ever mentioned. Looking at the painting, the Topgallants have been lowered. It makes sense to me as it would lower the center of balance.  Can anyone point me in the direction of further reading on this? Would this be a common practice?
Thanks for any further insight and education!
Mike Toole
Lancaster, PA
  • Solution
The photo shows the topmasts and topgallant masts "housed". All of the upper yards are "struck" or sent down. The topsail yards are lowered to the caps. The lower yards are also lowered to reduce weight aloft.  The ship is under "bare poles," (no sails) and "scudding" (drifting) before the wind.
The ship would be forced into this condition under a heavy gale with high winds and high seas.  She may have a sea anchor set out to keep her from getting beam to the waves so she doesn't capsize.
Regards,
Henry
Edited by popeye2sea
Henry
Laissez le bon temps rouler !
Thanks guys! I don’t think I have ever seen a model rigged that way. I will just have to keep looking!
Mike T
Mike T
Henry's comments are on point.  This image surely depicts preparation for sever weather.  Broken, or sprung masts were not a fun event and under sail...even less so.
Model builders...Unless you are creating a diorama event. tend to depict their models in pristine condition...at the height of the vessels condition. However,.......
With that said, you might find a model or two weather rigged in sucha fashion.  Good luck.
Rob
Current build:
Finished build:
Current build(On hold):
