Question about loading tackles in 17th Century Dutch Merchant Vessels
Go to solution Solved by popeye2sea,
  • Solution
Mast tackles are used to set up the shrouds. The topmast burton tackles can also be used to give additional support to the lower yard when the yard tackles are being employed to lift heavy items.
Regards,
Henry
Henry
Laissez le bon temps rouler !
On larger ships the loading tackle (burton tackle) ran down from the topmast head (assuming there was a topgallant mast). On smaller vessels without burton tackle came down from the lower masthead.
Phil
Current build: USS Cape MSI-2
I believe most vessels had mast tackles on the lower masts as well as the top masts. The mast tackle pendants on the lower masts had the additional function of being able to be rigged over the hatches to facilitate lowering cargo into the ship.
Regards,
Henry
Henry
