This is my Nordkap trawler build started in April it is based on the billings plans but since I wanted a small model it is built at 1:75 scale instead of 1:50 like the billings kit. This is my second scratch build alongside zwarte zee also 1:75. In the second picture you can see the small size of Nordkap compared to zwarte zee.
  • 1 year later...
Some progress on my Nordkap trawler. Hull painted and base coats on superstructure. Superstructure rear deck still needs much sanding and final coat. The yellow stripe on the waterline is tape. I will paint a white boot top here before clear coating the hull
