I started building my Terror recently, but have not gotten around to posting here. So, in honour of Jfj's mandible identification, I am finally sitting down to write this.   As of now, I am working on doing the second wood layer on the hull, which has been really fun. There is some general wonky-ness going on, but for my first time working with anything wooden ever, I think she looks ok.
 I think I should have sanded down the precut pieces that the hull strips got glued onto a bit more, because the second to last once specifically is a bit bumpy.
After a first sanding, she looked like this:
While i was waiting for the glue to dry, I had sarted building some other pieces. I am not quite happy with my first attempt of those crane-ish structures, the acrving on top looks a bit rough, so I shall try again later.
20240901_151131.thumb.jpg.fe25aa30f2fcacf0e378d994f916c0dc.jpg20240912_164919.thumb.jpg.2bb88ff9508452978b04853744818bf0.jpg20240901_184755.thumb.jpg.912114448f17a09a4a839fc20e7bc45a.jpg
Ignoring the instructions, i built on the ring part onto the hull firtst before adding the second layer of wood, because i was afraid of damaging it when sanding the ring. It worked fine.
I have now finished one side entirely and moved onto the other today. I have also begun thinking about paint, but since Uni is about to pick up again that might have to wait until Christmas break.
  • 8 months later...
Finally made some more progress on Terror! I finished the second layer of the hull and decided to glue extra wood to the inside of the railing for looks:
Had a delightful time putitng together more of the pieces that go on deck.
Proceeded with the windows and tried out some paining as I went along20250410_125739.thumb.jpg.4c3e26e0a186c2223c00d189c3d5006a.jpg
I struggled on deciding if/how to paint her but ended up settling on black. Unfortunately that made some of the gaps in the wood stand out so I added some filler and repainted her.20250412_112904.thumb.jpg.789613c489387f891773dbf5ce97fcdf.jpg20250412_121555.thumb.jpg.2d32e445a82a411b2be59dbb14103cf0.jpg
Rudder time!
I unfortunatly struggled with the metal sheets on the bow. Both the pattern and cutting/aligning them was really hard so I am not super happy, especially since i got a lot of dents and scratches on there as I went along. 20250513_220312.thumb.jpg.5449438d95fc207820dba4bfd309f830.jpg
20250614_190219.thumb.jpg.4b640adc408e8a4c12e8d5aafc6d0fce.jpg20250615_133847.thumb.jpg.cd4dbc180e4ffd6fc59e606559d49465.jpg
Next I will do these pieces, but I have not been able to consistently bend them in the same way. Right now I am using pliers... Stocked up on some extra wire though so I can get silly with it and hopefully get them to look better than the bow.
Edited by Lohengrin
