Live Shivers
Go to solution Solved by druxey,
I am wondering if anyone is able to help me in interpreting the following lines in a contract. In particular I am confused as to what “live shivers mean.” I have included both the original text as well as my transcription.
Mainsheet Blocks
To have blocks with live shivers, let through the side against the mizzen mast on the upper deck for the mizzen sheets, or otherwise as shall be directed.
The sheets pass through the side to come inboard for handling.  On some ships the "block" that they pass through is no more than a closed chock or hole through the side.  In this case they are specifying a rotating sheave let into the hole.
Regards,
Henry
Laissez le bon temps rouler !
