I am a newbie to this forum, and also to ship modelling - my modelling experience has mainly been plastic kits over many years - so I apologize in advance if this question is out of place. If I should be posting this question somewhere else in the forum I would welcome the advice.
I have read some of the build logs for this ship, and for the Terror, and there I found discussions about the "bulge" in the model ship's hull. I would like to modify the frames on my hull to take care of this, but I don't have the expertise to interpret the drawings and photos I have seen so far.
I have boiled my questions down to this:
Which of the frames should be modified? Is it 4, 5 and 9, whose profiles would need to be enlarged to be more closely matched to 6 & 7?
Has anyone created drawings of what the shapes of these frames should be, and if so, are those drawings available for me to create new frames?
I am really looking forward to building this model, and I suspect I will already have plenty of challenges ahead of me in the planking and beyond - but with challenges overcome  come rich rewards!
  Rather than try to modify some of the bulkheads before assembly, assemble them first and then deal with any bulges in the "fairing" process.  If you flex a piece of thin, straight spring wire stock over the bulkheads, it will be easy to see any bulge.  Then by sanding and frequently re-checking with the wire, you can achieve smooth lines/transitions.
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
I could make this work (I think) but first I need to answer my original question - "Which of the frames should be modified? Is it 4, 5 and 9, whose profiles would need to be enlarged to be more closely matched to 6 & 7?"
If 4,5 and 9 do indeed need to be enlarged, I will first have to cut new pieces - or "build out" the ones I have.
Guy
