I would like some input as to what I'm thinking about the finish of the lower hull on my HMB Endeavour. I use a mineral oil from IKEA to treat my teak table and chairs and was wondering if that would be appropriate to use on the lower hull, or maybe a linseed oil finish, then sprayed with a flat coat. I realize that this would alter the colour of the walnut planking making it darker. Further to this would an air brushed flat coat on most of the model be a wise decision?
Serpe, there are many  types of finish, different bases ,,,,, for myself I like an oil base stain, if staining. Shelac is my go to sealer , then a flat clear coat. If what I am doing is clear coat, then a  sealer, then latex varnish, oil varnish, wipe on Poly, the list is long.
 And yes even if you just clear oil finish  the color will change.
 Another thing to consider is does the  glue you will be using  stick to your finish, when you decide which one, test it frist.,
Good luck    :cheers:
Edited by Knocklouder
Typos
        USCG
Ich streiche meine Boote gar nicht.
Um die natürliche Farbgebung und Struktur zu erhalten, schleife ich alle Teile mit Schleifpapier 1000 und wachse alles mit Antikwachs.
Anschließend wird alles mit den Schminkpinseln meiner Frau aufpoliert.
Da ich in Zukunft die Möglichkeit habe reines Bienenwachs bei einem Imker zu kaufen, wird dies im nächsten Projekt getestet.
Grüße
Edited by Pfälzer
Aktuell Build:
Ranger - Corel
Victory - Corel
Endet-Build:
San Martin - Occre
Cala Esmeralda - Occre
Lady Nelson-Victory-Modelle
Gorch Fock-Graupner 1985
On Stock :
Yacht Gretel - Mamoli
Oseberg - Korabel
Naval Models - Paranzella
