HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
I am working on a scratch built model of HMS Bounty at a scale of 60;1 this makes the ratlines less that .1mm what thread should I use as this seems very thin.
Malc
Ratlines are about 1/2" diameter so at your scale, .008" diameter would be correct. However, anything within a hair of that would do, most likely.
Russ
Fly tying thread comes that small and is strong enough to work with, just make sure you get the round thread because they also have flat thread. Anyone need a lot of flat thread? :angry:
   Ron W.
Ron W.
Round fly thread? Could you give a source? The flat one I have is good for serving really thin lines.
Daniel
I use a black polyester sewing thread from Gutterman widely available every where - size looks good for 1:64 which is close to your scale. The threads easily to work with and comes in pretty long bobbins a good few hundred metres. The also do a linen version if you want a natuaral fibre.
Norman
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Russ
Scaling is always useful to 'judge' if the line thickness (and any other parts) look right.
I have been using thread that is .011 inch thick and to my eye it looks OK. Too thick, of course, when I scale at 1:76 it would come to 0.84 inch.
I hope that is close enough for Russ' hair.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
