I am building an 'Old' version of the Constructo Enterprise
My directions (what little I have) seem to imply I am to run two 'uncut' planks on either side of the keel line on the false deck, the entire length of the main deck, then stagger with 80mm planks across the rest of the deck.
Does anyone know if this correct or is it a poor English translation?
I looked at several pics but I could not tell if the center 2 planks were cut at 80mm or ran the length of the main deck of the ship.
The pic provides what I think is the correct layout.  The spacing is for visual clarity only, the actual application will have the planks with no spacing.
Current Build:   Constructo Enterprise
Hello. Go here and look for my article "Simple butt-shift deck planking"
It seems to have helped some people to do a proper planking job.
http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php
Hope this helps.
Edited by Ulises Victoria
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
When I built my Enterprise,  I scribed the sub-deck centerline (right across the  mast openings).  Then planked the scale deck planks  from stern to bow along each side of the centerline  then worked outward.  It created a "mirror image" of sorts.
