Continuation
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Deadeye with a diameter of 4 mm from a pear.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Information on the Montanes hull is additional
The hull  became covered previously with linseed oil and was dried about two weeks, then shellac not less than 10 times was brought - I precisely didn't consider, was guided on color. But it wasn't simple a covering, and shellac polish with intermediate polishings (the technology is described in many books on joiner's business, I was guided on described in the magazine the WOOD Master of N1, February, 2008).
For polish the orange shellac acquired in art salon is used. The choice of shellac and provisional cover was carried out by means of samplers with various combinations of coverings. I give a photo of one of samplers (at various lighting) on which figures designated various combinations of coverings:
1.  Karnauben wax, drying, some layers of orange shellac.
2.  Some layers of orange shellac on a clear wood.
3.  Some layers of lemon shellac on a clear wood.
4. Linseed oil, drying, some layers of orange shellac.
In my opinion, before applying any covering, it is desirable to check it on samplers from a concrete material of the hull.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Tools and the adaptations used for polishing of the case before a covering.
Best regards,
Garward
About the hull
Best regards,
Garward
Continuation
About the hull.
Best regards,
Garward
Continuation
About the hull.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
14.2.2 . Metal details mast
The brass tube is pierced to thickness of a wall of 0,8 mm then are cut, cut, adjusted to diameter of a mast in the corresponding place of a ring which then are soldered by the PSR 40 argentiferous solder.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Before installation on a mast of a ring 20% selenious acid are blackened.
Best regards,
Garward
Small nails
Good way of receiving small nails with a diameter of 0,5 mm with a hat with a diameter of 0,8 mm - use of contact legs from become useless printed-circuit board microprocessor. By means of a gas torch and a knife of a leg are disconnected from a payment, and then by means of a torch are blackened.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
