Endeavour J-Class by jdbradford - Amati - 1/80
!!!Correction to the scale  1:80 is what it should have been.  Sorry for the confusion.!!!
Well, I am finally starting my build log.  After much help from Richard, Dave, Floyd and others, I have my planking started.  I won't post the pictures of the materials as others have already done that, and I am past that point anyway.
I did build the boom and mast to start as per the instructions.  As we have seen in the other logs, they are not used at this time in the project anyway.  I also have one coat of flat white paint on them.  I must say again, the hinge that is nailed to the mast end of the boom was a pain for me.
In the mast drawing, it appears that the measurement listed to the first ring of 188mm is wrong.  It is no more than about 20 mm above where the boom hinge is attached.  I just used the drawing to lay it out.  I also did not get the holes as I would have liked.  I need a small drill press and a jig to hold the item in the correct position.
Current Build:       Model Shipways MS2015 - Fair American Kit bash
Previous Build:     J-Class Endeavor
Link to comment
Share on other sites
I followed this part up about a week later with the planking.
I could not tell from the directions where to start, it appears in the middle, but I did as Dave and started at the deck line, and then worked my way down as you can see from the pictures.
If you have any suggestions, let me know please.
Link to comment
If possible find some pictures that show the planking on this type of hull.  Other than following the basic rules of planking I would advice laying out some battens so you can visualize the way you want it to look.
David B
Link to comment
What you have sounds like a crimper.  It crimps the wood with little breaks.  For the veneer you are working with you can soak them in a container of hot water for a few minutes then tack them to the hull until they dry.  I have also made a fixture with the curve I want and clamped the plank to the fixture. If your wife has an iron take a wet towel and put the wood in it cover and run the iron at the highest setting over the towel.  This will steam the plank making it pliable.  Then tack it to the hull until dry.  On the full sized vessels they used a steam box to do the same thing.
David B
Link to comment
Looking good Jeff.
The recommendation to soak the plank and apply it to the hull to dry in a compliant curve is a good one. The plank will comply nicely without putting a lot of stress into the hull.
Another approach is to get a piece of 1/ 2 or 3/4 inch copper pipe, clamp it in your vise and insert a propane torch. When the pipe gets hot you can bend a wet plank by working it over the hot pipe. Takes a little practice, but it's an effective way to steam planks.
Dave Querin
Link to comment
That is a great idea.  I have my mother and wife looking for an old steam iron.  More bad news, the mahogany strips are .5mm x 3mm so after some sanding, they begin to get so thin it started to flake off.  I had to place some patches of strip in.  I may end up painting the entire hull.  I have finished gluing the decking and will post those pictures tomorrow.
Link to comment
Link to comment
I do not like how the 2nd planking turned out.  The plans discuss painting the entire hull and I am hoping for a few suggestions.  It says to use a spray on filler, I wonder if it means a primer.  But, the plans are not clear as to what to use.  I need a better finish on the hull before I do anything else.
Thanks
Link to comment
If you aren`t happy with the second planking, you could rip it off and start again, although that would be a lot of work. If you have some holes in the planking where you see the first layer you could sand of spare planks, put a drop of glue (careful though which you use, test it first on some scrap pieces, if you stain the wood the glue might cause problems) and put the sawdust in the hole. Another way would be to take planks rests and slip them in between planks that have some distance and carefully sanding off the inserted plank to the level of the hull.
Link to comment
If you plan on painting.  Use a primer first and this will also highlight any errors. Sand everything smooth. Then paint the color you want.
David B
Link to comment
Hi Jeff
looking forward to seeing your progress photos.
If you aren't totally satisfied with the results of your paint job you can try what I do for paint prep on my RC sailboats. After the first coat of paint, if I still have bad spots I re-sand until I'm almost back to bare wood. Then I go back and re-fill any low spots with red body filler from the automotive parts store. Once it cures I sand it back and re- prime to seal the new filler. Then go back to paint. A bit tedious but usually get a very nice finish.
Link to comment
My camera was acting up so I had to wait until today to get more pics uploaded.
I have painted the hull and finished the deck furniture.  I had to learn how to strop the rigging blocks, but got them done as well.  A few construction accidents at the shipyard and I will have to touch up the boat some.
I am finishing painting of the mast and boom today and will start rigging later.
Jeff
Link to comment
For the center stripe I used left over walnut and double stacked it, I saw you write about have bleed through from staining, that would have prevented the need for staining.
Link to comment
That would have worked.  I wish I thought of it. LOL
Man, I hate painting the cleats.  If they are supposed to be wood cleats, then that is what should be in the kit, not this crappy lead blob, with flashing all over and misshapen.
The brass handles on the pump are a pain as well.
Maybe I will have lots of spare parts when I get older.
Link to comment
Unfortunately some companies will use either plastic or pot metal for many of their fittings.  This is to cut down on costs.  The bad thing about it is the casting are poorly made so you cannot even get the dimensions.
David B
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
