igorcap
Everything posted by igorcap
  1. Very nice work , Alex ! I just thought about it, and you've already made. This will be a new revolution in modeling!
  2. Yes, this is an interesting topic. I also have a lot of ideas, but as long as there is no implementation. So I follow with interest this topic.
  3. Try like this http://forum.modelsworld.ru/topic1392start160.html
  4. Unfortunately I did not take photos during long period. Next picture: over external planking and gun deck
  5. Hello Wacko ! I use Rhinoceros as 3D editor , Rhino CAM ( CAM plugin for Rhino ) , LinuxCNC as controller. In Rino I work on for 14 years.
  6. Yes, I did it myself. First I made a 3D model, then CNC milling and final manual processing.
  7. At this point I interrupted work, because I received an order to build a model of Flemish galleon. Then I came back periodically to build of model but did not take a photo. A little bit about some detail .Decorative elements to the stern.
  8. Continued ... I marked and cut gun ports, tried taffrail and did lower hatchs
  9. A bit on the prototype and model. In reality, such a ship was not built ever. This is one of concepts that developed F.Chapman on request the Swedish Government in 1765. He was given task to create an inexpensive heavy frigate, which would battle with the ship line, if necessary. Frigate had to meet the following specifications: Dimensions Length 145' 6'' (imperial) Breadth 38' Draught Aft 17' Height of middle gunport above the water 6' 4'' L/B ratio 3.83 Armament 26*18-pounders, 12*6-pounders At least a decade ahead of it?s time when Chapman made the plans for this ship (the first french and british 18-pounder frigates were launched in the late 1770s). The guns are mounted on sliding carriages to reduce the number of men needed to operate them. In future, based on this concept F.Chapman built a series of heavy frigates type Bellona The model is built on the scale of 1/48 . Style of model should simulate naturally aged model of 18th century
  10. Next, I need to remove fragments of technological frames. I took a short video that showcases simplicity of this process http://sailmodel.ho.ua/present/09098288.MP4.mp4
  11. Then I begin to create base hull. Pine strips are glued to frames using a stapler. Total of two layers. First layer must be dried at least one day. After drying, staples are removed and surface is processing with plane .
  12. Next everything is done in wood. It looks simple enough but we are not trying to complicate things
  13. Then I get shape of "thick" frames from 3D for the manufacture base hull. A detailed description of my technology manufacturing basic ship hulls can be seen here http://sailmodel.ho.ua/present/pres_e.htm
  14. Thank you Mateusz ! Yes , I'm friends with Mirek
  15. I use extensively in their work 3d-modeling and CNC, so I started by creating a 3D model of frigate. Using this model I check all structural elements and can get shape of frames and other parts
  16. Hello everybody ! My favorite theme in modeling is Swedish shipbuilder F.Chapman and his ships. Previously, I have built a model of the Swedish privateer on Chapman's drawings from album «Architectura navalis mercatoria» (can see in the Gallery http://modelshipworld.com/index.php/gallery/album/208-swedish-privateer/) In 2011 I started to build another model of this album - a frigate (sheet XXXIII). This project was repeatedly interrupted, but I went back to building of model. I will show gradually all steps of building model. Baseline - Chapman's drawing. Analysis design of frigate has shown that this is an earlier and smaller version of the well-known series such as frigates Bellona (1782). Swedish Maritime Museum have excellent model Bellona 1/16. Photos of this model give additional information about the hull detailing and rigging.
  17. It looks great. I look forward to continuation ....
  18. Decor set for model of French corvette "L'Aurore". I show photo after CNC milling and final photo of decor on model. Model by Vadim Kuzmin
