KLarsen
Everything posted by KLarsen
  1. I've added the missing beam and all the knees, thanks again @druxey and everyone else for your input! With this I can continue with the quarterdeck: This is the view of the main deck and the captain's cabin: I decided not to add too much interior planking so the frames are still visible. It might not look as nice as the lower deck area which is completely planked, but having put that much work into the frames I didn't want to hide them away. When the deck is planked with a few strakes I can rig the rudder and then complete all the small details I've been putting off.
  2. That's a good point, thanks! Some of the other beams amidships have angled knees, but this beam sits right on the top of the gun port so I don't think that's a solution, as you point out. Wouldn't a horizontal knee help support the forces from the mizzen mast though?
  3. I've been looking at contemporary plans of Spanish (and other nations') frigates and ships of the line, and either they don't show the quarterdeck beams or there are none missing. I also can't see any reason whatsoever for the missing beam behind the mizzen, so I went ahead and prepared one. It's not glued in yet so I can still change my mind, but I think it's the most logical way to construct the ship. I can only imagine the mizzen would require some support since it's stepped so high above the keel, and a beam is the only way I can see to provide that. There's also still enough room to change the angle of the mast if that's something they did back then. Of course due to the gun port there's no room for a vertical knee, but I'll install a horizontal one instead which again would make sense to distribute the forces from the mast to the frames. Also, I'm probably overthinking this way too much! 😂
  4. I have an issue regarding the beams around the mizzen mast on the quarterdeck. According to the plans there's a beam missing here, with horizontal knees to add strength around the nearby beams. However the way the supports for the mizzen are shown on the plans frankly makes no sense to me. They are shown as resting on only one beam and the other side is basically floating free. Here I've colored the beams in green, the red planks are the support for the mast, which as can be seen do not reach all the way to the next beam after the wheel. The 3 azure parts are the ledges, and the yellow the middle carlings on which the ledges rest. The above quick sketch is my interpretation of the plans and the next sketch is how I believe it should be, by extending the mizzen supports all the way to the next beam, which if course would add weight on the real ship. I just don't understand why there's a beam missing here; maybe to allow for the rake of the mizzen to be adjusted? As it is now, there's definitely room for another beam though of course I'd have to remove the horizontal knees (I haven't added them yet). I wonder if anyone can enlighten me, if you know of any other ship constructed like this. I've looked through contemporary plans of other Spanish frigates but they don't show the beam layout for the quarterdeck. Edit: I forgot to add - the missing beam is right above the gun port, which would make it very difficult for it to have knees underneath it. Maybe that's why it's missing?
  5. I haven't posted here for quite some time, but nor have I progressed much. A friend of mine created the guns in 3d and I got them printed in resin, however I wasn't at all happy with the result so I got them printed in plastic instead. These turned out a lot better, but I'm not sure I'll use them. I'm considering turning them in bronze instead, though I've never tried turning metal. I'm now proceeding with the quarterdeck, I need this done before I can finish the rudder tiller and its rigging. Strangely there's a missing beam where the mizzen mast sits, I would have thought that area needed more reinforcement, although at least those beams will be supported by horizontal knees.
  6. The structure of the side galleries is finished. Later I'll create all the decoration. Oh, and the most important part:
  7. Thanks! And don't worry, I won't forget about them , they are a very important part of the ship! 💩
  8. I'm continuing with the stern and side galleries. I decided to make the stern piece out of one piece only, even though on the real ship it would probably have been planked. The sheet I used has a lot of grain so it's not easy to see that it's just one piece. I just think it looks better this way. For the side galleries, the plans are not very specific. There are only side and top views, and no indication of how it's built up. I'm building it the way I imagine it was built originally, more or less. Almost everything will be covered by moulding strips, which I'll make much later out of boxwood.
  9. During the last couple of weeks I finished all the rudder hinges, they weren't easy to make but I'm happy with the result. I haven't decided what to do with the upper hinge on the stern, the rest have a piece of planking beneath them but this one has a lot of curvature so I'm not sure if it'll look good. Also, keeping in mind that the planks would go across the hinge, not along it. By the way, the rudder turns just fine on the hinges. 😄 I've also been working on the main deck, much of what you see is only loosely attached until I install the rudder and the tiller (I'll need access below in order to seize the rigging). After finishing the tiller I'll most likely start working on the stern and side galleries, I'm getting a bit tired of making decks so the stern deck will have to wait.
  10. Very nice work, it's coming along great! However, when you lay out the frames to cut, try and use the curved part of the sheet to your advantage: some of the frames could have had the veins running all along them instead of across them. I always try to maximise the curved veins in a sheet when I'm lucky enough to get them 😁
  11. I finally got around to working on the rudder. Metalwork is something I'm very bad at, and I've been struggling a lot with the rudder hinges. In the end they turned out fine and I think the solder is strong enough so the pinion won't break off. 🤞
  12. There are only some low resolution photos on the Ancre website: https://ancre.fr/en/monograph/123-la-mahonesa-fregates-espagnoles-1789-9782382820131.html#/langue-1_2_serie_de_canons_au_1_48 Anyway I've got a friend of mine to create a 3d model of the cannons from the Ancre monography, if they turn out well I'll get them printed locally. Thanks everyone!
  13. Thanks, however the Spanish guns on that page are almost 100 years too early, so I'd need to create the 3d model myself from the Ancre plans. And as I said, I don't have the skills to do that. That's why I don't mind paying a higher price for 3d prints of the correct cannons from Ancre, if the quality is worth it.
  14. Sorry for reviving this thread, but has anyone bought any of the cannons offered by Ancre and can tell if they are of good quality? I'm thinking of buying some for my La Mahonesa cross section, and Ancre has confirmed that I can buy them piecemeal without having to buy a full set. They charge 4€ per cannon, which seems reasonable. I would make them myself, but my Blender/3D skills are basically non existent...
  15. Great start to a very interesting boat, I'll be following your log! 😄
  16. I finished the knees over the weekend and also created and installed the curved rail for the rudder tiller. Although I'm still missing the rearmost angled knees which are tricky to make. I had some difficulty installing the curved rail at the correct height under the beams, I opted to install it under a riser so the ends were at the correct height and the rail perpendicular to the keel. I looked at some photos of the HMS Victory for comparison. Next I will be partially planking the battery deck and preparing the pulleys for the tiller. Also, you might have noticed my photos are better quality, I just bought a new phone. 📷
  17. Continuing work on the deck beams and the knees. Before I can install all the beams I need to deviate a bit and build the rudder and its mechanism.
  18. I installed the inner planking and the huge curves tying the yoke together with the frames. With this I can begin fitting the gun deck beams, though before installing those I need to make the rudder and the tiller mechanism.
  19. By the way, I realise the way I've done the inner stern planking and the water way is wrong: it shouldn't be this wide but should have been more curved. I'm not sure why I didn't realise this earlier. Anyway I'm not going to redo it, I'd destroy more than I could fix, I'll just take it as yet another lesson learnt.
  20. This is what I ended up doing, thanks! In the end, no one will be able to see it anyway. I finished planking the middle of the orlop deck. I decided to leave the rest unplanked so the underlying structure can be seen, as well as the sail room below which is otherwise only accessible by the small hatch. The inside of the frames will be planked, this way it's easier to install the knees supporting the battery deck beams and the yoke. And since the wales cover the outside of the frames at this height, it wouldn't be possible to see much anyway if I were to leave the inside open. For the stern area I had to cut a piece from a sheet and shape it to fit the inside curves. There was simply no way I could bend a strip this much. Sadly the starboard piece broke at the end just as I was gluing it on, so there's a seem there that I probably won't be able to sand away.
  21. Continuing with the deck structure. I'll probably only install 2 more planks either side and leave the rest open except for the middle, which will be completely planked.
  22. Question: Does anyone know how the middle deck planks should terminate on the keelson? The plans don't really tell. I could either just make the planks butt up against the keelson or glue a strip onto the keelson and let the planks rest on that, nailing them in place. I'm leaning towards the last solution, I'm just wondering how it would have been done on the real ship.
  23. The main reasons I build models are: I like how I'm able to bring something I only have a mental image of into a real object. These days I only do scratch building from plans and have to interpret those and create a mental object of the ship, then start cutting the wood and actually build it. It's very satisfying to then see the final object realised. I build with wood because I like working with it and it is challenging; you need to know how to cut it the right way, it is not like plastic that can be cut any way you want. Also, I love the colour and finish of the wood. Why ships? Probably because I have a romantic view of them, there's something timeless and beautiful about wooden sailing ships. I build both civilian and military vessels but am mostly interested in Mediterranean ships from the earliest times till around 1800. The look of the ship is more important to me than its history. I'd much rather build a model of a completely unknown merchant ship than the HMS Victory. And lastly, it's relaxing! Sometimes when building I get completely absorbed and don't even know what time it is.
  24. To create the waterways for the orlop deck I first built up a template from thick crafting paper, then cut out the piece from wood and shaped it. It was the only way I could think of to get the complex curves correct. The plans don't show how the deck planks would be fastened at the very end, so I created a small piece and put it on the deck clamp. It's far from perfect but it won't be possible to see it once the deck is planked. I'll most likely plank the whole insides of this deck up to the main deck clamp, including the stern. Especially because I don't like the way the stern is looking right now where you can see the back of the outer planking.
  25. I'm not a kit builder but I have to admit that it's pretty cool! Much better than the Occre Victory kit from a few months back which just looked weird in my opinion.
