Ian B
Everything posted by Ian B
  1. Thanks Ken, not being a plane maker I really am enjoying this build, another week and it should be finished 😀 than back too boats lol
  2. Thank you so much, I spent 4 weeks searching for one on line..I'm itching to get my head down on my hns warrior build so perhaps later next year I will consider scratch building one
  3. Wings fitted, need to scratch a wiring loom and control cable from wing root to the fuselage
  4. Wings sprayed and lightly weathered..also pleased with the scratch build trim tabs and airleon actuators..next decals and the rest of the small bits pitot head. Folded struts, support arms for the folded wings,clear parts etc
  5. Thanks for compliment. I tried to get the 1/32 catapult that i know is out of production but was hoping an old kit was kicking around somewhere for sale.
  6. Ooooooops I had painted the flaps the wrong way around, time to rub back and spray the green and blue on the opposite sides...easy at this stage 🙃
  7. Thanks coming from you, just looked at your builds which are amazing. I don't do planes so this is a voyage of discovery for me
  8. Thanks Dan. I think this is enough paint it will look slightly more weathered once I have added the decals and a coat of matt varnish
  9. First coat of blue..the blanked off tips are yellow , ill keep layering the spray until the weathering/blue is at a leave that looks right..
  10. Thanks, the other forum building this kit did replace the canopy..I'm going to give it a go..then panic trying to source one after I mucked it up lol 😆
  11. Wings assembled , under coat as per the fuselage..loose covering of green metal,red dope fabric...dry fitted before I can settle down and paint them..
  12. Guns!! Barrels from Masters this is what the rear gun cartridge collector should look like This is what the kit had, along with a drinking straw from a small drink carton..Mal a chap also building this come up with this fix..so thanks Mal
  13. Surprisingly the aircraft carried its lifting cables externally where all weight is important to lug these around is a strange design decision 🤔 This bit of ugly plastic is the kits version So no self respecting ship builder on here could tolerate that..so made some That's Better
  14. Thank you all for your many likes and Wows..I'm really enjoying the change from my Ships. It is going to sit so well along side the Bismarck that inspired this build.
  15. At last the 3 sub assemblies come together..next canopy (apparently a nightmare to do on this kit) rear gun and radio aerials..
  16. All 'stickered' up. Each foot step was 3 separate decals so I had to apply some wear and chipping before applying them.
  17. Hi Hof Yes it's 1/32. Not sure if it is the new release dont think so. But the quality is super,I know I have changed bits but even a straight out of the box build it is very detailed. It was £35 from my local model shop..good value I thought The last time I made a proper plane was the later 1970s 😆
  18. Well it's sprayed! The two tone splinter pattern is very subtle. It will need some touching up around the cockpit and some other small bits..The white band is far to bright so I'll knock that back with the weathering
  19. Just a close up,I'm quite happy as I can tell what is metal and what is fabric, some nice contrast in the panels and elevator ribs just showing The picture does make the blue look slightly darker
  20. Then a red dope colour where there's fabric and RM02 grey/green where there is metal. Only roughly done as it's going to get it's proper colours over all of it. Should make a great effect when I apply the wearing/weathering
  21. Time to start painting the fuselage First some silver on where I want to rub back or chip
  22. Started on the flying surfaces , first re do the trim tabs, next i will do the same but larger on the rudder,elevator etc a bit of filing,a lick of paint should look 👍
