Everything posted by Ian B
Arado Ar-196 by Ian B - PLASTIC - German seaplane
Ian B replied to Ian B's topic in Non-ship/categorised builds
Thank you all for your many likes and Wows..I'm really enjoying the change from my Ships. It is going to sit so well along side the Bismarck that inspired this build. -
At last the 3 sub assemblies come together..next canopy (apparently a nightmare to do on this kit) rear gun and radio aerials.. -
All 'stickered' up. Each foot step was 3 separate decals so I had to apply some wear and chipping before applying them. -
Hi Hof Yes it's 1/32. Not sure if it is the new release dont think so. But the quality is super,I know I have changed bits but even a straight out of the box build it is very detailed. It was £35 from my local model shop..good value I thought The last time I made a proper plane was the later 1970s 😆 -
Well it's sprayed! The two tone splinter pattern is very subtle. It will need some touching up around the cockpit and some other small bits..The white band is far to bright so I'll knock that back with the weathering -
Just a close up,I'm quite happy as I can tell what is metal and what is fabric, some nice contrast in the panels and elevator ribs just showing The picture does make the blue look slightly darker -
Then a red dope colour where there's fabric and RM02 grey/green where there is metal. Only roughly done as it's going to get it's proper colours over all of it. Should make a great effect when I apply the wearing/weathering -
Started on the flying surfaces , first re do the trim tabs, next i will do the same but larger on the rudder,elevator etc a bit of filing,a lick of paint should look 👍 -
Scratch built the hydrolic lines that go to the floats that operate the rudder and added more tie down rings Painted up..now to concentrate on the fuselage -
Floats finished..added tie down rings and steering for the rudder.. No way us ship builders would stick a rudder on something with out steering controls lol 😆 The finish for the whole aircraft is 'seen a lot of activity ' weathered look -
Floats, a coat of silver then German RM02 green under coat. Once top coated ill weather parts down to expose the lower levels The only modified bits are a few extra holes drilled ready for later and an eyelet on the nose also for later. The wires at the back were for hanging during spraying -
This is just a truncated log showing high and low lights lol The cockpit which taking tips and ideas from a chap named Mal who is building a superb quality model of this.. -
Thanks Harry, Just clearing the decks ready to start hms warrior another big boat..also I so enjoyed making the two small Arado 196 sea planes im trying to build a bigger one i will put a truncated build on here in the right thread
Work area pictures only
Ian B replied to Johnny Mike's topic in Modeling tools and Workshop Equipment
Not many of us left..i have it on in the background sometimes whilst building..the bench is clear ready for starting HMS WARRIOR... big build! -
Sad news indeed, I contacted him via MSW a couple of years ago , he did an amazing picture of HMS Calipso in the English channel in ww1 for me celebrating my great uncles ship.. A copy of which a lot of my family have on their walls ..a very nice man
A little bit daunting when first reading the instructions for fitting the bow deck fittings, some very small drilling required!
