Seamus107
About Seamus107
  • Birthday 07/22/1946
  • Gender
  • Location
    Southern Maine
  • Interests
    Building scale models of small open boats that have historical significance; bird carving; woodworking
2,677 profile views
  1. I have a brand-new Model Shipways whaleboat kit, opened but never unboxed, including the paint kit. Below is a screen shot of the info on this kit from Model Shipways, as of today, August 11. I would sell the kit, including paint set, for $160 including shipping to an address within the US. Payment would be by money order or cashiers check - no personal checks, PayPal, or credit cards. Please contact me via personal message for details, if you are interested in purchasing the kit. Thanks. james Maine
  2. I appreciate and admire what you are trying to accomplish with this model, because I model small open boats with some sort of historical significance, many of which do not have published plans. You are creating something special from scratch, based on lots of research and considerable ingenuity. Excellent work! james
  3. Scratch building can be very challenging but very rewarding. I tend to choose boats for which there are no kits, so I have had to become a scratch modeler. I agree with John, that research and planning is important. You have to create your own “instruction manual” from plans or drawings before you cut or glue anything. Sometimes the research into the model and discovering the history of the boat you are trying to model are as much fun as the modeling! james
  4. It was a scratch build of a leithbhad, based on plans from the historic ships of Ireland web site. I added a load of turf to the hold, for the visual effect and as a conversation starter. I believe ship models should have a little something that will encourage the viewer to stop, examine the model closely, and ask the modeler a few questions. I could share some photos of the model, if you should ever decide to build one. james
  5. Welcome to Model Ship World! There are some fascinating Irish boats you could model, too. I have built a model of an Irish currach and recently finished a model of a Galway hooker. Lots of interesting nautical history from Ireland! james
  6. Thanks for sending me the link and photos of strip-planked peapod construction. We all hopefully learn something every day, and this forum is a good place to learn new stuff. Good luck on completing your house and unpacking everything. Looking forward to your progress reports when they resume. Maybe I will finish the Midwest peapod model, strip planking and all. james
  7. I started this kit more than twenty-five years ago, as an entry point into building ship models. Even as a completely naive modeler, I found many problems with the kit, especially with respect to the planking. I just couldn’t finish it, the planks seemed much too narrow, required bending in three directions (which wood doesn’t like to do), didn’t sit well on the forms, and didn’t resemble the planks on any of the small boats I see here in Maine. My experience with this kit almost discouraged me from pursuing the hobby any further. I rescued the model from a shelf in the garage last week, after having had a lot of subsequent experience in scratch-building small model boats, to see it I could make something of it. I saw that the narrow “planks” provided with the kit produced a very unrealistic planking pattern as one worked around the curve of the hull toward the keel. I thought it was me and my inexperience at the time I worked on the model, until I looked around on this forum and saw the same results from other builders. From my observations here in Maine, peapods and dories usually have 5 wide strakes extending from stem to stern, often in a clinker-built arrangement, that look nothing like the planks in this model kit. See the attached photo below, which is a screen shot from a video about building a peapod. I tried using lots of wood filler and sandpaper to disguise the planking lines and produce a smooth hull. It sort of worked on the outside, but not at all on the inside, where the twisted planks produced a ribbed look. Unsatisfactory. It doesn’t seem worth the effort to continue this way. I may recreate the stem and stern post, add a new midline plank, attach it to the base with the forms, and use this to create a hull with five overlapping strakes. Or, I may start from scratch and build a peapod model in the same way full-sized boats are built. james
  8. “Majority wins” is my motto in this case. If only one bulkhead seems to be too high or low, I assume the others are correct and sand down the high one or add material to the low one. Sanding away a bulkhead or two fore and aft of a low one might introduce asymmetry in the hull unless you do exactly the same on the other side, which then means you have substantially modified the shape of the boat. In my experience, the less you have to do to get a clean and true fairing job, the better. james
  9. I no longer have his user name, and there seems to be no way to find out a user name on MSW even if you have the member’s real name. That’s why I contacted an administrator who might be able to connect me.
  10. If I send you the member’s name, could you contact him and ask him to send me another personal message? I want to confirm that he received a book that I sent him. james
  11. A slip of the finger and a message thread disappeared. I would like to recover it if possible. Please advise. james Maine
