HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
palmerit
Everything posted by palmerit
  1. You might ask them if they have any on the way. I did get mine shipped from the UK because ageofsails was out of stock. They got a bunch in a month later. I don’t have a jig and I have tons of other (arguably unnecessary) tools. Something like the sherbourne is pretty small and you can just hold it in your hands. I also have it (now that it’s planked and painted) sitting on towels. Maybe when rigging it I might decide a jig is useful.
  2. Have you checked out Vanguard Models (https://vanguardmodels.co.uk). If you're in the US, you can order from https://www.agesofsail.com. The Sherbourne is probably the same price as the Titanic from Occre and has really clear instructions (though obviously very different ships). Vanguard also has less expensive fishing vessels. These models will keep you busy too. I've been working on the Sherbourne since summer. You can see the instructions on the Vanguard web site. You can see that they're a lot more detailed than the Occre instructions (just photos) and videos.
  3. Consider a Vanguard Model after you do the Shipwright Series. I’m doing the Vanguard Sherbourne (it was what I started first) and will likely do one or two of the Vanguard fishing boats before starting the Vanguard Duchess I bought. (I started the Shipwright Series while doing the Sherbourne for a model to work on when waiting for paint or glue to dry and for something else to work on). While the Vanguard models are more expensive, the instructions and materials are top notch, and things really fit together. The Sherbourne will probably take me as long to finish as it’ll take me to do all three Shipwright kits, so you get a lot of model dollars out of the Vanguard kits, with less frustration and head scratching.
  4. Make a copy of these instructions for "Free Dory": https://modelexpo-online.com/free-dory-promo.html?srsltid=AfmBOoqwmLrwPgSeQXL86b6R6YpMeUw_MBZ9VMjLAcP-eU_TtH8DMJMi If you complete it and send them a photo they'll give you a credit. I even got a credit for the Dory even though I bought the three-kit shipwright package.
  5. Relatedly, I'm wondering if people have suggestions for thin keyhole saws. I saw them used by someone building the Norwegian Pram, which I'm doing now. You drill a pilot hole and then can saw out a slot with the keyhole saw (obviously, something a razor saw cannot be used for).
  6. I saw these recommended here:
  7. First thing on these Model Shipways models (at least the Shipwright series ones), don't assume that the paper plans in the instruction book are 1:1 with the pieces. Often they're not. These models were developed a long time ago and I bet that photocopies were made of photocopies and the 1:1 correspondence may be lost. Sometimes they're right. Often they're not. I never checked them myself, but I read it enough times in other build logs that I don't trust the plans. Usually, you'd want to follow the plans. Not with these model kits. You'd think you should follow the plans. Not in with these. In these "older style" ship model kits, the pieces often don't fit together in ways described or illustrated (in contrast to more modern models by Vanguard Models). I certainly would not trim the cross piece, but just fiddle with the frames so that there they come together at the bottom they're parallel to each other (overlapping of course) and so that they can be glued into the side notches of the cross piece.
  8. I ended up redoing that first plank too - for the same reason. I ended up buying some more basswood sheets so that I could redo planks as often as I needed. I found that after redoing a few, I would have used all the basswood that came with the kit. I always made by planks too large and then just sanded them down to shape them. Probably a hack. But when I tried to precisely mark out the shape and cut them they were always off, and if they're too small or there's a gap you need to start over. Making them wider and longer made it easier to iterate. I definitely used the ultimation slicer a lot. One challenge I found is that you need to wet down to shape. But when wet, you can't sand or cut.
  9. I also have a ton of the plastic spring clamps (in three different sizes) and little metal clamps.
  10. I've made a ton of those binder clips and they are useful. I'll often put a piece of scrap wood down between the "clamp" piece of the jury-rigged clip and the piece of plank or other wood (especially if it's a softer wood that will be dented). I've just found that the binder clips don't work well if there a lot to curve and they don't work if there isn't room (e.g., if you're getting to the last few planks).
  11. Right. I've learned a bit to do the shaping of the planks. I suppose if I use a quicker setting glue (like the Tightbond Speedset) I can get by without lots of clamping. I've just seen a lot of various posts about the importance of applying pressure - some way the chemistry of the glue requires pressure, some say it's not needed. I suppose building a model - as opposed to a real ship (or a piece of furniture) - you don't need to worry so much about the pressure dimension of wood chemistry. It just need to stick and stay, hopefully for the long term.,
  12. Doing these bevels at the ends means that the two planks are flush (without a gap) at the bow and stern ends - if they were just overlapping and full thickness, there would be a small gap (and being a boat, you wouldn't want that gap). Along the length of the boat, yeah they overlap (clinker appearance) but there is no gap between them. It's only at the end (where they run up to the bow and stern pieces) that there would be a gap if they were left unbeveled. If you next do the Norwegian Pram, which I'm working on now, you do a rabbet cut at either end of the plank for a similar reason - not doing so would leave a small gap. I don't think I fully understood why I was doing the bevel when I built the Dory. I didn't fully understand the reason for the rabbet either when building the Pram, but then as I thought about it and played with the pieces a bit, it made sense. And then when I did the rabbet on one plank and compared it to the one without (holding them to the stern end) I could see that the one with the rabbet fit snug without much gap and the one without the rabbet had a gap. I wonder if they just had a rolling bevel on the Dory because it is a little bit more challenging to make a rabbet, so they included that in the second model, the Pram.
  13. Cool. Thanks. I'll need to try that glue out. Someone also suggested Super PHATIC ALIPHATIC Glue Fast Drying. I think that's more like a superglue but not as fiddly. I bought some to try to use with PE parts; it was suggested in the context of asking for an alternative to CA when using photo etch parts). Don't know how well it works with wood (it says it does, don't know how it'd compare to Titebond). I've also seen folks make their own pins that have a piece of wood through them (that can act as a clamp on the plank above or below) and that these work especially well when doing a second planking. I'd love a "how to" for making those (e.g., what kind of pins, what kind of wood). I'm not especially handy.
  14. After building my Sherbourne, I've realized that I do not like using CA glue. Maybe someday I'll gain the ability to put just enough glue, the confidence of putting it in the right place, and the speed to do it quickly. But that day is not today. I like using PVA glue. I can easily move and remove the plank. The question is how best to clamp it down. I know some people say you don't need pressure, but I've read that PVA glue binds better with some pressure. I've created some out of blinder clips (https://shipmodeler.wordpress.com/2015/07/01/simple-planking-clamp-from-binder-clips/). I've learned (from logs and playing around) ways to use rubber bands (and using clips to exert more pressure from the band. I have some plastic zip ties that I saw some people use, but haven't tried them yet. The blinder clips work well on a relatively flat area, but don't work as well on a curve or when there are other planks in the way. And of course they don't work if you're doing a double planked hull. I've seen people just use pins, but that looks like it would put a divot on the side of the wood if you apply any pressure, especially if the wood is softer. Can anyone point me to any good solutions I could buy or I could make?
  15. So even though I bought the three-model "MODEL SHIPWAYS SHIPWRIGHT 3 KIT COMBO SERIES", I was able to submit my receipt and a photo of me and my completed Dory to take advantage of their "Build the Dory for Free" offer (https://modelexpo-online.com/free-dory-promo.html). So now I have a $69.49 credit at Model Expo. Can someone recommend a good Model Shipways kit to buy and build? Here are the ones I've looked at: Bluenose 18th Century Longboat Virginia Armed Sloop HMS Bounty Launch I've checked out some build logs (more for some than others) but I didn't know if anyone had experience with these that could make a recommendation (whether they'd recommend one or another based on their experience building one or more of these or based on research they did in making a purchasing decision themselves).
  16. Maybe this is always the case (and I missed it) - or maybe it’s a special Model Expo often runs - but the Dory is now “free”. I put free in quotes because you buy it, then send a photo, and they’ll credit you the cost on your next purchase. https://modelexpo-online.com/dorycombo?srsltid=AfmBOoqbmKKhgvjx4gGEUQdS7N_Jqw_oKbTNAInzpJYtXEz1c5gkmq4o
  17. I did get the add-ons for the slicer and sander. Haven’t attached or tried them yet. They came with the set. I do need to sharpen the chisels. They’re sharp but can be sharper. When I bought the chisels, I also bought some stones and a guide for sharpening the chisels (and for sharpening my kitchen knives). Lee Valley has a nice collection of toys.
  18. Thanks for pointing out the @Modeller_masa build. I was finally able to use my tiny veritas chisels to form the rabbet (plus my files and a bit of sandpaper). One of the photos shows the garboard with the rabbet (right) and without (left). The one with does have much of a gap, the one without has a gap. Being a boat, in water, you would not want gaps. Thankfully my iPhone has macro mode so I could zoom into the rabbet for a photo.
  19. Ok, so this section is confusing. I think ultimately what you’re trying to do is make a small notch at the stern end of each garboard plank so the there isn’t a gap where the garboard plank, bottom plank, and stern transom all come together. It’s called a “gain” (a term I don’t remember from building the Dory) but also referred to as a rabbet here. Here I just have garboard (with nothing cut out) laying on the bottom plank and stern transom. I think I also need to make sure I bevel the stern transom so that the garboard lies flat.
  20. Trimming and sanding to the bevel the bottom and keel planks at the transoms after the glue dried overnight.
  21. Thanks! I guess I mean “sufficiently happy to want to go to the trouble of mounting and framing and hanging in our house”. I was happy enough to prop it up on a shelf in my office just now.
  22. I did some rebuilding, removing some planks, adding some new planks, and resending. It looks better than it did when I sanded through the planks to the frames. My next planking, I’m going to try to taper planks towards the bow with an eye to keeping them closer to the same dimensions and work harder to get them to lay better in the rabbet. On the “do over” I was a bit more impatient to just be done and move to the next thing. I was sufficiently unhappy with other parts that I had already decided not to mount it. I’ll probably set it on a high shelf in my work office.
