palmerit
NRG Member-
Everything posted by palmerit
- 81 replies
- half hull planking project
- NRG
I know by waterline 4, it’s just a mortise and only on the stem (the stemson is untouched). p. 8 says “above waterline 4, the entire rabbet will be on the stem side”, to accept a plank at 90 degrees. p. 9 says “the stemson side of the rabbet finally disappears just above waterline 3, the third line from the bottom”. and p. 11 has “at the third green line (at the point where no more wood was removed from the stemson), the rabbet will resemble a mortise or step rather than a V-shape” It’s pretty clear where the transition ends (right above the third green line). I’m not quite sure where the transition starts on the fore keelson to the stepson. I’ll need to reread and check some builds.
- 81 replies
- NRG
On the keel and keelson, I drew a straight line the width of the planking material (around .035” on my caliper). I tried using the compass I have, but mine wouldn’t get that narrow, so instead I marked the measurements from the calipers and drew a line between the marked points. I ended up drawing the line the same width on the inside edge to help keep the 45 degree angle. I’m going to make the rabbet a bit shallower than needed so that the resulting rabbet will accept the plank flush (with two sides of .035”, the hypotenuse - where the plank will hit flush - will be more like .049”).
- 81 replies
- NRG
I’m on the rabbet/mortice step along the keel and stem. So it took me reading the instructions a couple of times and reading through a half dozen builds to get to a point where I think I understand what’s going on. I’m sure I could have just followed the instructions and parroted other builds but I wanted to understand why I was doing these steps. Once you get it, it makes sense. It’s getting it that takes a minute, at least it did for me. I was thrown by the instructions that opened with “the rabbet is nothing more than a 90 degree groove cut into the keel/stern”. I thought 90 degrees relative to what? It wasn’t until seeing later photos in the instructions and in build logs that I realized the 90 degrees refers to the edge of the plank that will be laying inside the rabbet. The planks have 90 degree edges, so the rabbet needs to accept those 90 degree edges no matter how the plank enters that rabbet. I took some photos before cutting the rabbet and I’m using a leftover piece of pear wood plank from my Sherbourne (since the hull comes with sheets you need to cut rather than planks). The first photo shows that because of the fat bow on this model, the plank will essentially go into the sternpost at a 90 degree angle. That’s why the rabbet there is referred to as a mortise. It’ll be a notch the width of the plank. The second shows that along the keel, the bottommost plank (the garbourd) will intersect with the keel at a 45 degree angle (hence cutting a rabbet on the keel and keelson at a 45 degree angle. The third shows that the planks will run up against the sternpost flush, at a 0 degree angle. Later on the instructions, part of the deadwood will be sanded down so that the planks when installed are flush with the sternpost. It seems pretty simple once you get it, assuming I correctly understand what I’m aiming to do and why.
- 81 replies
- NRG
I ended up shaving a bit off the keel and keelson so that things lined up with the plans. The deadwood still doesn’t quite line up with G through H and there doesn’t seem to be an away to fix that.
- 81 replies
- NRG
So when I fit these, I assume the notches on the pieces (keelson and fore keelson) should line up with the red lines on the plan. They don’t line up now without cutting about 1 1/2 mm from the keelson.
- 81 replies
- NRG
Cut out the keel, stem, and stern pieces and laid them on the board. Need to sand the char and check for fit before going to next steps.
- 81 replies
- NRG
Started by mounting a photocopy of the layout on a piece of 1/2” foam core board I bought at an art supply store.
- 81 replies
- NRG
Still struggling a bit with planking, I decided to take on the Nautical Research Guild's 18th-Century Merchantman Half-Hull Planking Kit (aka half hull planking project or the half hull) before continuing with the rest of the boats in the Model Shipways Shipwright Series. It has a long tutorial book and several builds to follow, including one by the developers of the kit: Some Lessons Learned (Post-mortem): I added this note after (nearly) completing the model - I wanted to point out issues folks taking this model on might want to make note of: 1) Definitely don't rely on the instructions alone. They're generally well-written. The illustrations are not the clearest. So check out a lot of build logs with nice photos. Bookmark a few. The one by @JacquesCousteau is nice. As is the one by the developer of the kit (linked above). 2) Pay close attention to the stern end of the model. You really want to check out successful build logs to see what it should look like and how the planks should lay. There really is a lot of fairing that needs to be done and careful attention to the transom and counter. 3) Don't be afraid to make the rabbets and mortices a bit deeper so that the planks can really hug in there. 4) What might be easily missed in the instructions is that the counter (at the stern) actually needs to be shaped. It has a curve in it. 5) The instructions suggest maybe waiting to add the transom and counter because they might get knocked off when fairing. I followed that advice and then realized that I had faired the last few ribs too low and had to add wood back and reshape. If anything, I suggest adding the transom (gluing it in place) and shaping the counter so it's ready to fit in (but not gluing it in place until after you fair). Having the transom in place lets you check the fairing. Leaving the count off lets you really get into the stern end where a lot of work is needed. 6) Also check on where the counter will fit in and mark its location on the last piece of the skeleton. That'll let you know if you're fairing too much. 7) Make sure you check, re-check, and re-re-check the fairing on the bow end. I ended up having too much of an elbow and lost some of the smooth flow that should be there. Get some really flexible buttons that will let you really check how blanks might lay (basswood is too brittle to use as a batton - if you bend it without wetting it, it will break). 8) Basswood is really soft. If you get an indentation, you can often wet the wood down and it'll spring back to shape after it dries. It's also easy to bend. I never had to pull out my heated plank bender. Just needed a little water. You definitely don't want to glue wet wood, so let it dry first. However, being soft and thin also means that it's easy - as I did - to sand through the planks right to the ribs - which I did.
- 81 replies
- NRG
- 28 replies
- Lowell Grand Banks Dory
- Shipwright Series
(and 3 more)
- 28 replies
- Shipwright Series
(and 3 more)
Shaped the oars just with sanding sticks and sand paper. They’re supposed to have a thin part at the end but I misshaped a couple and ended up just rounding them all.
- 28 replies
- Shipwright Series
(and 3 more)
It was. Thankfully, they were just laid in place when I took the photo.
- 28 replies
- Shipwright Series
(and 3 more)
I don’t know if it’s the model, me, or both (mostly me I think). The thwarts (seats) are supposed to slot into the frames, but the boat seems to be too wide in places (especially in the middle). If the boat was too narrow, I could narrow the boards. The thwarts being too narrow, there is not too much I can do (except recreate the thwarts with new would, which I’m not inclined to do for a boat I just did for some more practice). Come to think of it, I think when I put the planks on, I didn’t ensure that they were fully touching with frames in a couple places, especially in the middle. Then I had to wet the frames to get them to touch the planks and that widened the boat enough to have the thwarts no longer fit. A small error that’s corrected can impact something later in the build.
- 28 replies
- Shipwright Series
(and 3 more)
Got the first couple coats of paints applied. While I have an airbrush, here I used the Model Expo paints that came with the trio of models. I didn’t want to experiment trying to thin it for the airbrush (or search for and order matching Vallejo paints), so I just used a paint brush. I did thin it a good bit with water since it was pretty thick, almost house paint consistency. Better to do a few thin coats than apply one or two thick coats.
- 28 replies
- Shipwright Series
(and 3 more)
- 28 replies
- Shipwright Series
(and 3 more)
- 28 replies
- Shipwright Series
(and 3 more)
- 28 replies
- Shipwright Series
(and 3 more)
Definitely a bit of a challenge doing a single plank hull compared to the double plank on the Sherbourne (on top of the other differences in design and wood).
- 28 replies
- Shipwright Series
(and 3 more)
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
Another couple of things that have been really helpful is an Optivisor and really fine point paint brushes. I bought an Optivisor with a 2.75x lens with a Optiloupe auxiliary lens (which gives another 2.5x in one eye). I bought mine from Otto Frei (I buy tons of stuff on Amazon, but I don’t trust resellers). I wear my eyeglasses while wearing the Optivisor. And it rotates up so I don’t need to take it on and off. I buy brushes at a local art supply store. I started with what I thought were really small 1, 0, and 000 brushes. But I’ve since bought a 00000 and a tiny 18/0 for painting while using the Optivisor.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
A possible suggestion for the pure novices like me: I really haven’t liked worked with CA (super) glue. For my next double planked hull, I’ll probable try using wood glue and clamps, even if it makes the second planking take 4x as long. But you can’t get around using CA with PE (photoetch). It’s not as much of a challenge (for me) when doing something like glueing in an eyelet or belaying pin: I just dip the end of the piece into a small pearl of glue and then insert it in place. It was using CA on flat PE parts that gave me a headache: such as the tiny Roman numerals on the prow. When poking around on some general modeling YouTube videos on using PE I saw the suggestion of instead using a flat clear acrylic print instead of CA (which I later read in some instructions for another Vanguard model). Being paint, it’s slow to dry. And it stays flat (both physically and in sheen). I used Tamiya XF-86 Flat Clear to attach the hinges on the companionway. After everything gets a matte varnish, I’m guessing it’ll all be as secure as if I had used CE.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
You’re right. I’m learning how to work with this soft basswood. I loosened them a bit now that the glue has set. I did end up bending one of the frames pretty bad when I attached the garboard plank because I had clamped it (as opposed to clamping a rubber band). Thankfully, this softwood can also “bounce back” a bit and if you really wet it down and reshape it (I reshaped the frame element by clamping a couple of flat pieces on either side).
- 28 replies
- Shipwright Series
(and 3 more)
Been adding parts to the deck. I just have to do the cannon a bit more pieces and then it’ll be on to the masts.
- 177 replies
- Sherbourne
- vanguard models
(and 3 more)
Making progress on the Dory. While easy, it’s definitely not as self-explanatory as the Sherbourne (and the instructions and photos and illustrations for the Dory aren’t quite as helpful).
- 28 replies
- Shipwright Series
(and 3 more)
