Everything posted by michael101
Thank you David i did the sanding in the firs stage by the way before sanding i made an external support for the corner of the keel in the manual they say that the secunde keelson will be install after doing the second plank ... its mean that aria of sanding will be without support because the L supports that i made on the construction board not going to support that aria they will touch the keel above the sanding aria , and the corner of the keel can get curve until you will finish plank the first plank so first of all i cute some plywood same thick as the keel and same hight as the first keelson (11mm) and drilled exactly in the middel of that plywood to the bottom of the keel then i connect the external plywood by brass pin and now the L support are holding the sanding aria exactly in the middle of the L supports here some pictures : and for the pillars for sure i will follow your advice ! Regards , Michael.
Hello Paul , thank you! , and that its true not all the bulkhead going until the end of the keel .. But On the secund question i was asking about the distance between the Decks take a look at the distance between the decks from the firs deck to the second deck is perfect, but from the secund to the third and also the third to the fourh is not the same as the plans ... any way like the disiner say above there is no problem ... you cant take the plan as a guide because the drawing showing cross section
The answer for that is : i have called caldercraft today and send them the pictures i have talk with the guy how design that ship and he told me the middle gun deck mast be 145 ! so the problem is the bulkhead and just need to sand the slot and also the bottom of that bulkhead and i asked hem if need to sand all the down part of that bulkhead or only the corners the answer is : only the corners of the bottom and he told me dont worry you will need to take a lot from that bulkhead doing the fairing also i have ask: when i check the plans there is something wrong with the top of all bulkheads take a look at this pictures from the middle gun deck to the second deck its like in the plans but the third deck and the fourth deck is not suitable with the plans and he told me: the drawing and bulkhead are both correct. The drawing is a cross section through the centreline of the ship and therefore shows the midline of the deck; due to the deck camber this point is higher than the reference point you are using on the bulkhead shown in your picture (the middle deck has no camber which is why it appears to align correctly) hope its will help someone Best regards , Michael.
hello again very important : i got a little issue and it will be good to post that issues here : if im understanding good the plans , the middle gun deck need to be perfectly straight 145 mm high from the keelson (including the keelson) the problem with bulkhead 13 that is flash with the keelson line like he need to be in the plans … but the deck line is 1 mm above the 145mm line of the middle gun deck… so im not sure if the problem is in the bulkhead 13 and i need to sand 1 mm from the slot and also from under the bulkhead , or the problem is in the plans .. and from bulkhead 13 the middle gun deck need to start going up .. please need your help with that issue also i compre bulkhead 12 with bulkhead 13 i put them flash in the deck line and bulkhead 13 its higher than bulkhead i mean from the deck line to the bottom of the bulkhead here is some pictures
Hello Charter
How are you?
I saw your beautiful build log of the victory
now im going to start building the same ship god willing
I will be more than happy if we will make a contact by Facebook or other way to chat online
best regards
Michael.
- Show previous comments 9 more
Thank you !
i have post the answer in my build log ...
any way i think to close that build log i guess its only you and me in that build log LOL
cheers,
Michael.
Read your build log and the answer all seems to make sense. Replies to questions posted on this site can take a little while to come back either because members work during the day or live on the other side of the world and are currently asleep!
Looking forward to seeing your work progressing.
Graham
Hello friend Im about to start building the h.m.s victory of caldercraft but before doing anything i have some questions , Someone know how long need to be the planks of the deck of the Middle gun deck? I want to mark the lines before insalling the deck Also beside the build log that i want to do in msw, if someone building that ship or going to build that model i will be more than happy yo make contact with that person by facebook or other media that we can chat online , Best regars Michael.
Thank you Cathead
Survey of wooden Mississippi riverboat kits.
michael101 replied to skipper1947's topic in Wood ship model kits
Thank you all -
hello friends i was looking for the Mississippi River Steamboat 1870 and i see a lot of kits with different scale can someone give me a review on that ship also i never build a kit of sergal can you review that factory the link for that kit is : http://www.cornwallmodelboats.co.uk/acatalog/mantua_mississippi.html b.t.w mantua and sergal is the same factory? thank you and best regards Michael.
have you start to build one of the kits? -
hello friend we have a friend in our grope that has a medical issues , and his family want to sale his kits... i see in the list of the models that he has the flying cloud of mamoli and i can get it for 260 usd and i want to help hIm , I believe he needs the money for his issues just want to know if someone has Experience with this model and if the frames are laser cut ? please i need the answer soon as possible thank you and best regards! Michael.
nails brand
michael101 replied to michael101's topic in Building, Framing, Planking and plating a ships hull and deck
thank you all i bout the nails of amati and they looks very good -
hello friend do someone have the micro shaper mp400 of proxxon? im just about to buy one today and i will be more than happy to get your recommendation best regards Michael.
