wernerweiss
Posts posted by wernerweiss
Hello modelers,
as already mentioned in the Confederacy build log of Walrusguy (here page 7), this is not a build log but a series of pictures of my model showing the progress of the build.....
As I have now been building for a few years, I begin with the latest pictures and upload the rest time by time.....
I look forward to your questions and comments.
Greetings
Werner
Hello Walrusguy,
I first contacted you when I visited your build log of the Confederacy and drew your attention to a mistake you had made with the planking.
In the following I invited you to visit my gallery of my Confederacy model in my german forum, and you registered there and therefore are able to watch the progress of my build.
As we two are by far not the only builders of this ship and because I like to watch other build logs, I have decided to start a new topic here with the pictures of my build so that all those who are interested can also take part. As already mentioned before it is a gallery and not another build log with detailed descriptions of how I did it.
So to all who read this, come and see..... any questions, comments and constructive criticism welcome.
I will begin with the latest pictures and upload the rest time by time....
Greetings
Werner
21 hours ago, WalrusGuy said:
It was brought to my attention that the lower most plank at the stern counter should follow the entirety of its length together with its moulding (I really appreciate the feedback since I can fix it early on!). After seeing it end partially, it is starting to bug me whenever I see it. So I plan to fix this before progressing with the build.
I am also considering to paint the counter planking blue. Another option I am considering is to slightly open the gun ports. I want to try making working hinges (no idea if I can pull this though), so this will be a good experiment for me. The red line here indicates the required curvature of the bottom moulding to follow the curve of the plank.
This curve is consistent to the plans as well (http://www.modelshipbuilder.com/e107_images/custom/hahn/confederacy/Article_confederacy_03.pdf)
I'm going to take a small break before commencing on this fix. It's a good chance to continue working on Pickle. I always welcome constructive criticism to my builds. It helps me improve and avoid mishaps 🙂
Hello walrusguy,
I must admit that I was a bit astonished when I first visited this log and saw the pictures showing how the hull planking matched with the planking of the lower counter along its bottom edge.
My way of construction was to build the planking of the lower counter as a separate part - similar to the sub-deck platforms - using the stern view on sheet one (similar to that above) as a template, see the respective pictures from my german forum (sorry, uploading didn´t word, don´t know why.)
However, I think it is not really a problem for you to get an excellent fix.
A very fine model with all the treenaling and the coloring in red and blue!
There is a point in the building instructions I did not agree with and therefore changed the way of construction. The lower moulding strips shall be glued on completely, which means they have to be removed partially where the channels are to be mounted. I changed the way and glued the moulding strips in seperate pieces alternating with the channels. I hope you don' t have too much work in removing the concerned segments of the moulding strips.
More pictures of my model in the german forum coming soon!
USF Confederacy 1778 by wernerweiss - FINISHED - Model Shipways - 1:64
Hello Walrusguy,
now I need your help.......trying to upload more pictures always ends with "upload failure"........do you have an idea why?
