Everything posted by baribeaujm
Chapter 5 I received Chapter 5 yesterday and started on it. I show below the parts received: I recognize most of the laser cut sheets as discussed in Chuck's log. Sheet Y seems to replace the second layer of the upper bulkhead S (the part with the column etched on it in Chuck's log). The monograph of Chapter 5 should clarify that. Anyway, a lot of precise work ahead of me.
Cabin Planking I do not want to stay idle on this project and got on to do the cabin's planking. I first checked the aft platform height with the planking extension template. The fit is very good as seen below. For this I had to scratch the beam clamp. Thanks Chuck for providing the drawing. It is a relatively easy task, the main challenge being to make exact mirror copies port and starboard. I was happy with the outcome: I used the template to scratch the planks. Those are a bit tricky to glue on because of the subtle bends and the challenge to clamp those in place. Here I used modified clothespins to secure the planks in position: The next photo shows the finished work. A bit of a gap aft, but this will be hidden when more parts are added. Aft Lower Partition I decided to scratch the aft lower partition as well. I followed the plan carefully and made minor adjustments to fit my model. Very little adjustments were actually required, which is nice. Nothing is glued yet and a little more narrowing at the side is needed to account for the inboard planking. Notice here that the midship beam clamps are also installed and a beam was scratched to check the partition positioning. Everything seems in good agreement with the plans. The work on this section will resume when parts become available. Fore Partition I decided to scratch this section as well. It is a fun little project and there is to char to remove! The parts copied from the plans fit nicely. Again, nothing glued yet. I also started to work on the fore castle. I installed the beam clamps and scratched a few beams. More on this later.
Aft Platform Time to report on my progress. This time it is the aft platforms. But before doing that, I need to mention that I finally discovered where the small triangular pieces of chapter 2 are going. These complete the last cant frame at the transom as shown in the photos below, before and after fairing. Yes they can be omitted, but they should help to secure the corner of the side plank that will be glued later. For the platform framing, I proceeded as before with cardboard height references. To get to the proper height I needed to do more fairing of the frames. It is a bit tricky to get all those beams a the right position with clean adjustment at the frame. Here it is very helpful to work with a card board template of the platforms. I found it easier to assemble the platforms separately. It easier to cut out the hatches and sand the planking. The upper platform was done the same way. Adjusting the upper platform height is easier as the bottom platform and the bottom of the transom can be used as reference for the fore and aft ends, respectively. The inboard great cabin planking expansion (plan sheet four) is also useful to check that the upper platform is at the correct height. Here are a few shots of the completed platforms. I can now probably do the cabin wall planking while waiting for the next chapters.
Please note that LASER stands for Light Amplification by Stimulated Emission of Radiation. Nothing to do with energy or amplitude.
Fire Heart Here I fellow the instruction steps with no major issue. I opted for the beaten up option. I used a Touch red geranium marker to color the bricks and soot and dark rust powders to season the bricks. I used the flour trick to enhance the mortar joints. I painted the hood with my go to Admirality's metal black and finished with soot and rust powder. A couple of vies below: Next is the aft platform beams and forthcoming Chapter 5.
Fore Platforms I first prepared paper templates of the lower and upper fore platforms and tried to position them on the model. It revealed the I needed to do a bit more fairing at the bow for the platforms to sit at the proper height. Once the firing was completed, I started the beam construction. I tried to use Chuck's height gauge, but found it tricky to position. Instead, I use cardboard height guides for each beam as shown below. This approach worked well for me. Next photo shows the completed beam structure. The platforms were assembled on a flat surface and their contour adjusted to fit my model. Their shape is virtually identical to the plan. Proceeding this way makes it easier to sand the planking and to cut the scuttle lids accurately. The platforms were then glued on the beam structure. A light coat of WOP was applied to enhance the planking joints. I then completed the breast hooks and riding bitts. The next photo shows the completed fore platforms (riding bitts not glued). Hopefully every thing is sitting at the right height and positioned correctly. Next is the fire heart and then Chapter 5!
Stern Details It has been a while since I reported on my progress. For the stern details I followed the instructions. For the bottom molding, I used a fairly similar pattern as the one starboard and port. The frieze was then glued with little tweaking to adjust the width and size. The upper molding in two layers was scraped and glued on. Here is a general view: The columns and carved transom were done next. The laser parts fit quite nicely and only little tweaking is needed here. Here is another view: I painted the top of the transom with a mix of black, burnt sienna and blue, trying to match the frieze's background. Once everything was glued in place, I noted the some of the background black was showing between the carved transom and the windows. I may have to scrape that paint or move the carving down slightly. I will address that later. I then proceeded to complete the molding to wrap around the stern and provide a base for the two standing figures. This is a rather tricky operation and there are a lot of angles to adjust. The next photo shows details of this construction: The last step is to carve the figure bases and glue the standing figures. I dry fitted these and realized that there is very little area available to glue the figures on. Therefore, I decided to postpone this step for now. I doubt that I could complete the project without knocking those off a few times... Limber Strakes As chapter 4 was not out yet, when I reached this point, I decided to make the limber strakes from scratch. I created the rabbet by gluing two 3/64" planks shaped according to the plan. A bit time consuming, but no char to deal with! I received Chapter 4 just in time to carry on with the project. The mast steps were added next. Next I will report on the platform construction.
Fancy Molding and the Frieze - Starboard Side Work on the starboard side is completed. I tried to keep a good symmetry between port and starboard. Here are some pictures: Anchor Lining I found that using individual planks worked better for me. It allows more accurate positioning with respect to the hull planking and it is easier to conform with the hull curvature. Here use of CA glue helped a lot to maintain individual planks in position while being slightly bent to follow the hull curvature. This completes chapter 3. While waiting for future chapters, I plan to do a bit more work that requires no laser cut parts (transom and some framing) to keep the project going.
The Stern Lights The build continues. There was no particular issues with the stern lights. The fit is very tight and it cannot be emphasized enough how important it is to use the blanks provided when building the transom. The image below shows the result. (A good dusting of the windows will be needed). Inboard Sheer Planking and Final Cap Inboard planking is straightforward using the pre-cut planks provided. Before gluing them on I had to do a light inboard sanding to insure a final width of 1/4" of the hull at the sheer. With the inboard planking in place, a light sanding of the sheer line using the long sanding stick described in the instructions was done to insure that the final cap was horizontal. Once in place, I sanded the final cap to get nice joints and no irregularities. I found important to reduce the width of the cap in the waist section as much as possible so that the last 1/8" fancy molding is flush to the cap. Fancy moldings and the frieze The fancy moldings were scraped using a razor blade. For the lower molding I chose a very simple profile that mimics that of the quarter badge as shown here. For the upper molding I used a slightly more detailed profile. As discussed above and in the instructions , it is important that this upper molding meets the final cap at the waist. This requires making slight adjustments to the frieze width to account for the cap thickness and width of your final strakes. In my case I printed the frieze at a 110% magnification to get a nice fit. The above photos also show the fancy moldings at the drifts. I found the char marks on those can be lightened slightly by soaking in water and brushing. The anchor lining was then added. I found I got a nicer fit using individual strakes rather than the one laser piece provided. Need to complete the starboard side now in anticipation of chapter 4.
Treenailing This step was faster than anticipated. I used a no. 78 bit and 10 lb. monofilament. The fishing line used is burnt orange, which softens the contrast with the yellow cedar planking. I found that for this repetitive task it is better to work in short sessions. After a half hour of marking, drilling, etc. it easy to loose concentration and make mistakes. Better to stop and return to it later...I inserted the fishing line directly into the drilled hole. It was a tight fit and no glue needed. Completing the Planking The final two strakes and drifts were added next. This is again fairly straightforward. The only tricky step here is to cut holes in the planks where the sheaves are positioned. Shaping and gluing the drift at the bow is also a bit tricky since it is above the rabbet. Here are a couple of views. in these shots you can see that WOP was applied up to the 1/8" stakes and that the second layer of the wales was completed. I decided to paint the wales before gluing them on. I used Admiralty Matt (Metal) Black, which I always use for wales, spars, etc. Applied in several dilute coats it produces a superb finish. Finally, I dare to show a front view of the bow. The overall result is not too bad. The strakes are slightly pointing upwards at the bow, which suggests insufficient fairing close to the stem. There are small strake height variations from starboard to port. Fortunately, a lot of this will be hidden when additional elements are added at later stage of the build. Preparing the qbadges and fancy moldings For these, I used the fruitwood gel stain method. I am more or less happy with the result. The staining is not uniform and a showing too much orange shades and build up in some areas (stain too old?). I will experiment with IPA to see if the coloring and uniformity can be improved before I glue those on the model. I welcome suggestions here.
Removing the JIGS Before removing the jig, I decided like others to reinforce the frames by inserting fillers at the sheer. This is probably not needed, but should add some rigidity when fairing inside the hull. Removing the jigs was straightforward. No issues here. As instructed, I used a long sanding sticks to create a smooth even sheer line. The hull template is useful here to tweak the sheer. The fairing Cap and Inboard Fairing I added the fairing cap making sure I do not mix the two middle sections. Then came fairing inboard... This is a long process. It took me several tens of hours to complete this. I used only sandpapers and sanding bars of various grits. Fairing at the bow is especially tedious because that section is quite concave and hard to reach. I also added the keelson as you can see. Planking Above the Wales I completed the planking up to the 1/4" strake. Here the planking template is very useful to shape the planks at the bow. I tried to follow the plan as much as possible trying to match the strake height with respect to the gun/seep ports. I found it important to check the exact width of my 7/32 planks and make adjustments where necessary. Errors are cumulative and it does not take much to deviate from the plan. A few photos follow: The next step is treenailing. I will report on this in hopefully a not too distant future...
Hull Planking I proceeded with the hull planking as per the instructions. The paper template is crucial for adjusting the position of the sweep ports and gun ports. The height of a few gun ports sills had to be corrected (never more than 1/32") to conform to the template. Some sweep ports were a bit off and this could be taken care of by tracing their exact position using the template. I guess these slight adjustments are unavoidable given all the possible variations in frame construction and positioning. Adjusting the upper wale height at the bow is a bit tricky. For this I positioned a 1/8" guide as shown here. With the upper wale position established, I proceeded with the planking. For shaping the planks I used the travel iron and air dryer technique. I used a combination of CA and PVA for gluing. I typically would apply CA to 10 consecutive frames and ten PVA on the following 2-3 frames. The CA glued section is position carefully and once the glue is cured, the PVA glued buffer gives me easy access and time to apply CA glue to the next 10 frames. I found this approach insured that all frames were glued to the plank, avoided CA messes, and minimized the risk of opening gaps at the joints when CA is used at once over the whole length of the plank. Before planking above the wales, I checked the width of my 7/32" planks. My planks were a hair too thick (0.225" instead of 0.219"). I used my Varitas mini plane to narrow the planks down to the correct width. Slightly thicker planks would have led to complications when planking around the ports and shifted the position of the fancy molding. I completed the first three rows plus part of the fourth. A milestone has been reached. It is now time to remove the jig!
CHAPTER THREE The Square Tuck And Counter Planking Because of a Canada Post strike, delivery of Chapter Three parts was delayed. I wanted to carry on with the project by scratching these parts. For the square tuck I used 1/8" thick AYC billet for the planking. The border was shaped with files and sanding sticks from a 1/8" AYC sheet. It is tricky to get good symmetry between the two sides and reproduce the run from the plan. If you want to make your own square tuck, the width of the planks needs to be very accurate. The planks should be 0.248-0.250" wide, except for one plank (second from the top) that is 0.225". It really does not take much to offset the planking pattern. For tree nailing I used 15 pound fishing line and the taper was adjusted to fit my framing. Overall, I am quite please with the result. For the counter planking, I cut planks from a 3/64" AYC sheet. These planks were shaped according to the drawings with very little tweaking needed.
Stern Framing Merry Christmas to all! For the stern framing I followed the instruction. The notches on the jig really help to position the stern frame accurately. This is something I struggled with in previous builds. Here everything went smoothly. The fillers were useful to position the light sills. The angles of the provided parts fit closely to the model with only minor tweaks required. Note that an additional slight taper is needed to fit the outer edges of the sills where they meet the quarter pieces. For gluing the transom, I proceeded with caution as recommended. Not much issues here. The final step was to glue the triangular pieces on top of the quarter pieces. I left enough room for later adding the fairing cap and final cap. The last item not discussed here is the adding of the upper port sills. When doing those I realized that some of my lower sills were slightly off (angle and height). The variations are small (typically 1/64"), but it is bugging me. I will do minor adjustments before planking. More about this in Chapter 3.
Aft Cant Frames More progress to report. The aft cants are assembled and mounted the same way as the fore cants. No major issues here. On some frames I had to do some adjustments to get a good fit on the apron. This is probably because some of my apron wedges were not perfectly centered or slightly off vertical. The shorter half cant frame at the last gun port is a bit tricky to adjust, but the templates greatly helps for proper alignment. The above photos show the aft cant frames before fairing. Fairing requires s lot of sanding, specially at the apron. The main challenge here is to obtain a clean profile where the cant frames meet the lower apron. As you can see, more sanding will be required when I do the final fairing. The Wing Transom I proceeded as described in the instructions. Here the main difficulty is to glue the wing transom so that it is perfectly horizontal, perpendicular and centered on the keel. I found that dry mounting the quarter pieces helped in that regard. I also used a combination of squares aligned to the build board plan as instructed. Once the transom wing is well positioned, it is easy to permanently glue the quarter pieces to aft cant frame 24. As mentioned by others the cant frames need to be faired to do a proper alignment of the quarter pieces. The Fashion Pieces and Last Aft Frames Here I followed the instructions and had no major issues. Thee was a lot of adjustments needed to get all the angles right before gluing the fashion pieces. The last aft cant frames also required some angle adjustments. I noted that my frames were an hair thicker than the 0.25 inch prescribed. A bit of sanding was required to get them to nicely fill the gap between the fashion piece and frame 24. I struggled a lot to get a good fit with frame 29. The bevel markings on the pieces is a good start for shaping those pieces, but a lot of adjustments were required. After several hours of testing, I was able to get a decent fit. The photos below show the results before and after fairing. I was able to improve the joint at the apron, but more sanding may be required to get a perfectly smooth transition. I believe the small inaccuracies in the positioning of the apron wedges is making fairing difficult here. It should look better once WOP is applied. The last photo shows a view of the stern after fairing. A bit more fairing may be required.
The Fore Cant Frames Work continues on the Speedwell. Preparing the cant frame is a long process. Lots of char to remove, joints to adjust, tree nailing to do, etc. I found the cant frame jig work very well. Once the jig is positioned properly, adding frames one after the other is relatively straightforward. As suggested in the instructions, I first installed the first three fore cant frames and then switched to frame 11 and worked my way towards the bow. Some tweaking was needed at the lower joint between the frames and the lower apron, suggesting my apron wedges were not perfectly vertical. The above photo shows the starboard cant frames after some preliminary fairing. I tried to keep the bottom joint as clean as possible with minimum gaps. The Bow Timbers I shaped the bow timbers as instructed. I found that my bevel lines were systematically lower than the edge of the forward cant frame. This was probably because I had some initial fairing done on the frame. Anyhow the assembling went smoothly. No particular issues here. The above images show views of the bow timbers after assembly and fairing. There is a bit more fairing required near the keel and at the sheer. It is quite tricky to get the hull profile right where the frames have an inward curve (concave). I will address this later.
Mounting the Frames and Fairing I finally completed the square frame installation. Once you got the hang of it, I progressed fairly quickly. Here is one side view: I found it important to check verticality whenever a frame was added. Some frames were slightly off, possibly because of minor misalignments when frame parts were assembled. The seven-piece frames on each side of the gun ports are the most susceptible to this. A few remarks: I opted to sand the frame sides and apply WoP. This represents a lot of work and it is arguable that this is needed at all. The gun port template is very useful to position the sweep ports and sills. However, it works best if the upper section of the hull is faired. As indicated in the instructions it is important to shape the sweep ports so they nicely follow the fairing. I also partially faired the inside as I progressed. I decided to treenail the frames prior to installation. It is easier to get the distances and angles uniform. The following images show starboard and port views after fairing. For the most part I used Vallejo flexi sanders of various grits (see photo below). I found these work very well. Contrary to emery sticks those flexi sanders do not gum up and last forever. There is some residual fairing to do, but only after the cant frames are installed. It this time to start Chapter 2!
Very well done, Glen. Yes this part of the build is challenging indeed. There are so many angles. Just eyeballing stuff just does not cut it. I found getting those timbers vertical and correctly spaced quite tricky. You did great! The cat head supports are also fun to adjust. Expect a lot of back and forth here. Jean-Marc
- 840 replies
- winchelsea
- Syren Ship Model Company
Frame Assembly I can finally report on the frame assembly. I worked slowly, trying to adjust the various parts of a frame as best as possible. I found getting nice clean scarf joints on fore and aft sides of the frame not that easy. The method I used was to work on a glass plate on top of a mirror as shown below. This allowed me to check the fit on both sides simultaneously and make tiny necessary adjustments. In general I achieved fairly good results, doing my best to minimize gaps at the joints. Cross Piece Jigs The next step was to glue the cross piece jigs on each tall frame. You want to have the jig perfectly perpendicular to the frame so that once assembled together the jig pieces are nice and flat. Just eye balling here is probably not good enough. To get those jig pieces square, I stuck them on a flat board with double side tape and used a set of squares to position the frame perpendicular to it. The photo below shows my setup. There are certainly clever ways to do this, but that approach worked for me. As for the short frames, the handle bar was glued on with the frame put on a graph paper to check for and correct any asymmetry. The photo below shows some of the completed frames. As with any repetitive task, I found my technique improved as I was making more frames. I would recommend to not begin frame construction with the very critical midship frames Aa, Af, etc. Any inaccuracies on those will affect the adjustment and alignment of frames as one proceeds from midship to bow and stern. Mounting the Frames Here I followed Chuck's instruction. Getting the first frame nice and square is critical. As suggested, I used a set of squares for this. I clamped a tall square on both side of the board to center the frame. Squares were used to insure the frame was perpendicular to both the working board and the keel. Like others, I found the frame was a touch inside the breadth max line (about 3/64). Adding frames was fairly straightforward, but as I proceeded, fine adjustments were needed to correct small misalignments due to frame construction and jig installation. The photo below shows the first seven frames mounted and sweep ports installed. To keep the sheer line nice and not jagged I had to glue on a piece of plank to keep the jig pieces aligned. This is likely the result of small skewness in some of the frames. This clamping of the jig induces a small amount of stress to the frames, but hopefully this will not be consequential once the hull is planked. I used the provided template to adjust the sweep port positions. Very little adjustments were needed. Just keep the the top of sweep port filler aligned with the sheer line. Incidentally, the sweep port pieces add a lot of rigidity to the whole assembly. I would not attempt any fairing without those in place. I dry mounted a few more frames as shown in the photo below. I am a bit surprised on how some of the frames (4f and 5f) seem to not follow the general inboard hull profile (they fit the outboard profile nicely). Is this the way it should be?
Nice Shawn, I am also making frames. I did a quick check with frame Ba (Aa not done yet). My frame is also slightly inside the line (less than 1/32 on each side). I was quite aggressive with my char removal and this could have slightly reduce the width of the frames. Also, a frame not perfectly square with the respect to the keel or slightly higher on one side than the other will bring the frame limit inside the line. I am curious to see if I get closer to the limit line once I have made all the necessary adjustments. I will keep you posted. Jean-Marc
Frame Preparation The next step is removing of the char on the frame parts. The layer of char on those parts is quite thick and cleaning them up requires a fair bit of work. The photo below shows the tools and equipment I used for this task. Char from the hull (concave) side of the frame can be removed using sand paper. First using standard woodworking 400 grit sand paper and then finishing with waterproof automotive 400-600 abrasive paper. I find the later works very well. Since it is black, every sanding stroke is clearly seen so it is easy to move your part around to clean areas at every stroke (sanding over a dirty section of the sand paper just imbed the char within the wood fibers). Once the sand paper sheet is saturated with char, it can easily be cleaned by soaking in water, dried and reused. For the inside of the frames (convex regions) I first used Lee Valley's mini scrappers. Most of the char can be remove this way. A clean surface is achieved with further sanding with sanding sticks of diamond needle files. I use a crepe block to frequently clean the sticks and files from accumulated char. Otherwise the char removed is simply moved around. With the same idea in mind, it is a good idea to keep your working area clean by frequent wiping/vacuuming. All this is done wearing a N95 mask (a must) and optional nitrile gloves. Frame preparation is a slow process. It took me about three weeks to complete the square frames. By the end, I could complete one frame in about one hour. Once the char removed, I also sanded the frame sides to remove any residual char. An example of a completed frame (10f) is shown here. Note the misplaced notch in one of the parts (lower right hand corner) for this particular frame. This is the only part that shows such anomaly. Hard to understand how this could happen in the production process. If others see the same it could indicate a mistake in the drawing file used with the laser cutter. The next step is the frame assembly. At this point I am wondering whether or not WOP should be applied to the sides prior to assembly? It is not clear to me how the frame sides can be finished once assembled (how to deal with the various steps when scrubbing with a steel wool) or installed on the keel (limited access). I welcome suggestions. I am also trying to devise a method to keep joints as tight as possible and minimize skewedness of assembled frames. The photo below shows all the frame parts s in individual ziplock bags ready for assembly.
Thank you all for the likes. Stern Post While most of the keel parts were glued on a flat surface, this proved problematic for the stern post. With the rising wood protruding and the stem taper, the assembly is no longer flat and it is difficult to proceed the same way. To keep the stern post perfectly vertical, centered and aligned to the stem, I rather used squares to keep the whole assembly vertical and aligned. See photo. I applied a couple thin coats of WOP on the completed assembly. I show close-ups of the stern and stem below (note the knee of the head finally glued on). After application of WOP the wood got a bit darker than expected. Does WOP have a limited shelf time when opened? In the past I have used nitrocellulose sealer. This is great stuff. It does not change the wood color, gives a nice satin finish and dries almost instantly (70% of the content is VOC!). It is however a pretty nasty chemical and it is hard to find (banned in North-America?). I got mine from the UK many years ago but nowadays suppliers will not ship this abroad. I find WOP a good alternative. Building Board This has been covered by others and I essentially followed their foot steps. The MDF boards I could find in hardware stores were not flat. I resorted to a melamine board and glued my plan with repositionable spray glue. It is now time to work on the frames. Stay tuned.
