KeithAug
Everything posted by KeithAug
  1. Keel and building board location slots. The important thing here is that the keel and building board slots are accurately cut to width and that they are in perfect alignment with one another. I did consider cutting them freehand but decided to try and find a way of slotting them out accurately on the mill. The slots needed to be ¼ inch wide to match the ply that I intended using for the keel. I started by making a jig for drilling - see photo. With this I drilled holes at the inner end of the location slot in all the frames. By drilling trough the frames and the jig I created a position for a location peg (1/4 inch diameter) which meant I could accurately reposition the frames to drill the ¼ inch holes at the end and at interim positions in the keel slot. I should explain that I am drilling using a mill with an x/y table. I am keeping the y setting locked and only varying the x setting to accommodate the different positions of the keel slot. I am therefor ensuring that all the drilled holes are in alignment and at right angles to the building board edge of the frame. To cut the slots accurately I decided to use a slitting saw mounted in the mill. My first operation was to mount a piece of wood vertically in the mill vice. I then locked the mill spindle and machined off the upper edge of the wood using the slitting saw, thus ensuring that the saw cut relative to the wood was the same for all subsequent cuts. See Photo. Using the ¼ inch holes in the frames with a pair of location pegs I then clamped the frames to the wood with the pegs tight against previously cut surface. Once clamped the pegs were removed. With the slitting saw (still locked in its preset vertical position) I then cut one side of the keel and location slots (obviously two cuts from opposite ends). See Photo. I then unclamped the frame reinserted the dowel pegs flipped it over re-clamped and repeated the cuts as before. Result! – accurate ¼ inch keel and location slots perfectly aligned.
  2. Sorry - first mistake is title should say scale 1:32 - anyone know how to edit titles?
  3. ALTAIR is an auxiliary gaff rigged schooner built by William Fife & Sons at Fairlie as yard number 789. She was launched in May 1931. The 1.32 scale model plans were created by Sandy Cousins and produce a model 1200mm LOA and 200mm Beam. The plans are on 6 sheets and include building notes by the author. The plans can be used to create a sailing model. To achieve this requires the addition of a significant extension to the keel in the form of a metal plate some 100mm deep with a swing keel pivoting below this. As I am building a static display model I don’t need to worry about this. So to begin……….. I chose this build as as I had really enjoyed building the Amati Endeavour 1:35 kit but wanted to return to scratch building for my next project. My daughter bought me the plans and they were delivered by Santa a couple of weeks ago. As designed the plans suggest that the main frames are made from 1/8 inch ply stiffened by several 1/8 inch ply “decks” forming a box structure. This felt overly complex and I resolved to make the frames out of ¼ inch ply as I had done on previous models with a ¼ inch ply keel running the length of the model. The plans also suggest that he hull is constructed attached to a building board. The allowance for the upstand from the board seemed excessive and potentially wasteful so I reduced it by about 1 inch at the bow and about 1.75 inch at the stern. I will step the building board to allow all frames to sit correctly relative to one another. I considered a number of options for marking out the frames. As per normal practice only half frames were drawn. The building notes suggest transferring the outlines to the ply using carbon paper. I didn’t fancy this and decided to cut out the frame outlines from the plan and then mount the half frames on card to create templates. The templates were then used to transfer the outlines onto folded paper. Once cut out and unfolded I had the frame cutting profiles and these were attached to the ¼ inch ply with Pritt Stick glue. I tried a few arrangements to get the minimum waste. Before cutting out the frames using a jig saw with a fine cut blade. I don’t have a scroll saw and cant justify one for the limited use I would make of it. After a number of hours of careful cutting I finished up with a reasonable set of frames. I have left the frame keel slot and the building board locating slot uncut while I decide how to saw these accurately as this will be key to a successful build. Well thats enough for now - back to more sawing tomorrow. Keith
  4. Hi Julie One of the benefits of backing that I didn't mention is that mistakes are buried under the following layers. One of the things I most like about model boat building is that its new every time. No two boats are alike and in consequence each one throws up new challenges. Overcoming the challenges and correcting mistakes is a key part of the fun and satisfaction. I did wonder about the rasps - I have never used them and in fact don't own one. I tend to use coarse oxide paper (60 grit) on a sanding block for roughing out - followed by progressively finer grades for finishing. However inspired by you experience I have just ordered a set of rasps. Keith
  5. Julie Re clinker effect. If you try to bow a plank in 2 directions at once (i.e bow in the weak and strong direction) the wood tries to deal with the stress by twisting. This causes one corner to press in to the backing. In my case the upper edge was trying to dig into the backing. The zoom on the photograph and the sanding exaggerates the effect. In fact the step between planks was at worst about 1/3 of the plank width. The only way to eliminate the clinker is to taper the planks and by doing so only have bending across the weak direction. Of course tapering takes a lot more time. On previous builds with more complex hull shapes I have tapered the planks. With Endeavour I felt the lines were fine enough to get away without tapering albeit at the expense of sanding about 1/3 of the 1st planking away in some areas. I wouldn't however have used parallel planks if I hadn't backed with balsa. The good news however is that the 2nd planks bing very thin bend very easily and in consequence exhibit no tendency to clinker. I like your wedge approach to straightening. Did you do the wedge cut outs on both sides before installing the wedges in the 1st side (important as the compressive strength on the 2nd side will be high without the wedge cut outs). Keith
  6. Hi Julie I applied glue to the hull for the entire length of the plank so that the back of the plank and the edge of the plank abutting the previous plank was glued. I didn't size the balsa. Not sure if the glue shrank the balsa - I didn't notice it doing this. I did secure the planks quite well during gluing so they were pressed hard against the backing and the previous plank- see photo. if you have distortion in the hull it may reveal itself when you are planking the deck - mismatch between deck planks on either side (which I always think is very irritating on the eye). Better to correct it now.
  7. Hi Julie You still seems to be going well. like you I find rubbing the palm of a hand over the surface to be a good method of checking the shape. Because the balsa sands away more quickly than the frames it is very difficult to avoid some flattening of the profile between frames. Slight flattening isn't however a significant problem as it tends to be compensated by the 1st planking. In the attached photo I have done a light sanding of the 1st planked hull - you can see the areas where the frames have caused the planks to be raised. As sanding proceeds these raised areas are removed - see 2nd photo. Like you I found the rudder wasn't the correct shape at its upper end. Also the plans show a weird discontinuity between the rudder and hull at the base of the rudder - I ignored the plans in this instance. The instructions don't seem to cover what you do about finishing the rudder. Have you decided what you are going to do? Keith
  8. Hi Julie, Well done so far. I am assuming you will soon starting 1st planking so here are a few pointers assuming you are still planning to start at the deck and work to the keel. I am going to split the advise into 3 parts. Part 1 - the first 1/3 of the hull from deck to waterline. The planks tend to want to curve in their most flexible direction. You should find that these planks go on quite easily and that with care you will get good plank edge to edge contact. Part 2 - the second 1/3 of the hull from waterline to the merging of the hull and keel. As you progress you will find that the planks become increasingly difficult to hold flat to the backing. This is because they naturally want to bend in 2 planes at the same time - bowing in their weak direction to follow the backing and bowing in their strong direction to butt to the previous plank. This double bowing is generally seen as undesirable as it can lead to twisting of the planks resulting in a "clinker" type effect. I had some of this on my build. However being aware of the problem before I did the planking enabled me to control it to a level that could be sanded out. I have attached a photo of the "clinker" area after a light sanding. A way of avoiding the "clinker" is to abandon parallel planing in this area and start tapering the planks. This inevitably leads to a lot of shaping and the need for closing triangular fillers. Part 3 - the third 1/3 of the hull from the hull / keel merge line to he base of the keel. As you progress beyond the hull / keel intersection the need for bending in 2 planes diminishes and bending in the weak plank direction becomes dominant. Planking therefore becomes easier once again. However the bulb of the keel starts to make its presence felt and bending the planks around its leading edge becomes impossible because of the sharp change in curvature. It is at this pint that you need to start laying the thicker bulb planks along the length of the keel (on the centre line). I have attached a photo to illustrate.
  9. Hi robnbill It is still destined for my daughters flat - but we agreed it was better suited to an internal wall as it would be less vulnerable to accidental damage. I hadn't considered your point which is a good one. Keith
  10. Julie Another option (and possibly simpler) is to buy a sheet of 2mm ply and use that instead. However if you want to use backing I think you could restrict it to the larger openings on the centre line. I was careful to make sure that I applied ample glue to all surfaces - including the hull backing balsa. And I did use a lot of elastic bands to hold it in place. I also used a scrap piece of wood to make sure that the centre line contacted the frames. - see photo. The blue and white headed pins are the temporary location pins. Keith
  11. Julie, Re diagonal planking. I did try out diagonal planking of the mahogany second planks. I convinced myself that it would work but in the end decided to go with planks parallel to the deck because I thought it looked better. I didn't consider diagonal planking on the 1st planks because they are thicker (less flexible), changes in curvature are significantly more pronounced and double curvature ("s" shaped) occurs in the area of the keel. This isn't the case on the picture you have posted. However try it with one or two planks as I did with the second planks. An advantage of the deck attachment sequence mentioned previously is that the 2nd planking is displaced by 1/2 a plank width from the first (because of the thickness of the deck and deck edge plank. This means you don't get seam on seam even though the planks are parallel.
  12. Julie Clearly the deck will flex under undue pressure. What I mean by perfectly solid is that it took the deck planking without any distortion and the finished deck (with planking) exhibited no perceptible deflection under thumb pressure. I have just rechecked the thickness of a scrap piece of deck plywood and its thickness is 1.02mm or circa .050". I have also done the thumb check on my model and I can't detect any weak areas. Regards. Keith
  13. Hi Julie I had variations in backing thickness - Its difficult not to have this and it does not matter. I wouldn't worry about it. I know that the deck plywood is thin but if its like mine the quality is good. I din't find any need to put backing underneath the deck and the result was perfectly solid. Have a think about the sequence of attaching the deck. I did:- 1, First planking. 2, Attach the deck. 3, Deck edge plank, 4, 2nd planking. I can see pros and cons for reversing steps 1 and 2 but would probably keep this sequence if doing it again. Steps 3 and 4 need to be the final operations so the mahogany planking goes right up to the deck edge (covering the plywood and deck plank edges). Keith
  14. I think the problem with painting the hull relates to the Amati kit. It gives the option of leaving below the water line as mahogany while at the same time providing mahogany planking for the entire hull. The quality of the mahogany is good and when varnished it produces a beautiful rich finish. Lovers of natural wood tend to baulk at the thought of burying it under layers of paint. Also the creation of a mahogany finish provides an added challenge for the modeller. Inevitably the finish has to be achieved without recourse to filler. The care and attention needed to achieve a high quality mahogany finish can be the added challenge that the modeller needs to test their skills and deliver the satisfaction they desire. Where the accuracy of reproduction is not the primary aim the finish is really a choice for the modeller. The advice posted on finishing options may be very useful to Julie but the advice I would give is - "follow your heart". Keith
  15. Hi Julie It seems to be going well. In the end it will all be worthwhile. Keep checking the alignment - for bow and twist. Particularly if you are working on one side first. You may need to work from both sides to control distortion. Keith
  16. Hi Julie This photo (borrowed from another members build) gives some idea of the problems encountered without backing. If you consider the sanding needed to get this smooth you will appreciate the degree of plank thinning that is involved. By way of contrast look at this on my build with backing. Zooming in to both photographs shows the issue better. Regards Keith
  17. Hi Julie I used the backer for a number of reasons: Because of the thinness of the planks and the wide spacing of the frames I knew the planks would want to curve more at the frames and flatten between them. This would mean that the hull would not change shape smoothly. The lack of smoothness would be greater than could be taken out by sanding - inevitably leading to sanding through the planks as they passed over the frames. The backing significantly reduces / eliminates this problem. Perfect edge to edge butting of successive planks would be very hard to achieve. This type of butting invariably leaves isolated areas where the planks have some misalignment. A misalignment of 1/2 the plank thickness (only .020 inch) would mean half the plank thickness would have to be sanded away to create a smooth hull. The resulting thinned hull would of course be very weak. The backing significantly reduces this problem. The backing stabilises the frames meaning you can complete the planking of one side before starting the other. Without backing you need to alternate planks from side to side. This is a more difficult operation because where the planks close at the bow they want to cross. Although the backing does aid fairing of the frames its main purpose is to address the planking issues identified above. Keith
  18. Julie Re 2nd planking - realistic mahogany plank lengths. This is my best shot of the end butt on my 2nd planks. This is at high magnification. The end butts are hard to see on the finished model. Shortening the planks to a scale length might actually make the laying of the planks easier. On the other hand it will make it more tedious. The decision on what to do is down to you and what makes you feel good. Long or short planks are both wrong on this model because as you say the hull was metal. As you are not constrained by the accuracy of reproduction constraints my advice is to do what makes you feel good.
  19. Hi jmcsys I find experimenting is one of the most enjoyable part of the process - it always feels better when (after a number of failures) something works. Thank you for your comments. Keith
  20. Hi Julie You seem to be doing very well. Re frame additions - if I am looking at the right bits these are because in the Amati build method the planks are only long enough to reach about half way along the hull. They have therefore given you a double frame thickness to land the end of the planks on. I don't like this solution as it means all the plank ends finish on this central frame - giving a distinctive line of weakness. Planks which alternatively land on different frames give a more realistic and stronger solution. You may be able to see this in the attached photo. Keith
  21. Hi Julie Sorry to hear about the glue problems. I didn't experience this so I can't provide much advice. The general purpose wood PVA glue I used did not start to go tacky until about 5 minutes after application, neither did it appear to swell the wood leading to tightening of the joints. It is however water based so I can see that it could soak into the wood causing swelling and tightness where joints are particularly well made. One alternative is to use 2 part quick set epoxy. I used this extensively on my first model for gluing the frames. The advantage is that it does not soak into the timber to any degree and also has self lubrication properties that ease the slipping of parts together. The down side is that it is a bit more time consuming to make up and clean down. You may need to experiment to find the best solution. Keith
  22. Hi Julie I was trying not to be too dogmatic in my views. I think I will come off the fence by saying that I think tacking the deck on is in general a waste of time and effort. Indeed if the skeleton isn't distorted you may even get away without the need for a strong back. The strong back does however have the added benefit of easing holding / fixing during the planking operation. I think my kit had been badly stored at some time before purchase as the plywood was bowed slightly when it came out of the box, this led to the distortion in the assembled skeleton. The shim method for the strong back works well. Happy shopping! Keith
  23. Hi Julie The strong back contacted forward and aft (on the longitudinal stringers) with a little clearance on the intervening frames. I used spacers at the stern end to take care of the athwart ships curvature. Effectively the strong back was locating solidly at 4 points. This was enough to adjust the slight sideways bow and more pronounced twist in my skeleton without altering the hull fore to aft curvature. You can see from the attached photos that the strong back is about 2/3 the length of the hull. You can also see the spacers (white card) in the bottom left corner. My interpretation is that Amati want you to use the deck pinned in place while the skeleton is glued and thereafter removed while 1st planking is undertaken. This is particularly important with the Amati (unbacked) planking solution as you would need access to the backs of the planks to ease them into edge to edge alignment. This access is available for the initial planks but soon disappears as the planking proceeds, unless of course the deck isn't fixed in place until later. Keith
  24. Hi Julie My observations on the questions you pose are as follows:- The round mast bothered me also - particularly as the 1989 Endeavour definitely has an oval mast. If I had thought about it early enough I would manufactured the mast out of a square section core with semicircular dowels front and back and then tapered this. I didn't and made do with a round mast. This isn't ideal but wasn't particularly noticeable on the finished model. Pragmatism over perfection for me in this case. I din't nail the deck in place as suggested in the instructions. Bolting on the oak plank strong back removed the need for attaching the deck until after I had completed the 1st planking. Having completed 1st planking I cut a dowel of about 1 foot in length and the same diameter as the mast and used this to align the forward section of the deck relative to the frames (similar to what you are doing). With the deck in place (held with elastic bands passed around the deck and hull) I used a square to make sure that the dowel was at right angles to the deck fore and aft. As the deck rises towards the bow this gave a natural rearward rake to the mast. I also used the square to judge that the dummy mast was at right angles to the deck athwart ships. Because of the curvature of the deck the latter operation required equal thicknesses of packing to be placed at the deck edges (to compensate for the curvature). Once I was happy with the location of the dummy mast I drilled though the deck into the frames at a number of locations with a 0.5mm drill. I then removed the deck applied the glue and relocated the deck back in position using dressmakers pins through the pre drilled holes (no nailing required). The deck was held in place during gluing with elastic bands. Once the fore section of the deck was in place the rear section was easily located by butting it up to the fore section. I wasn't content with accepting a straight mast but also wanted to impart rearward curvature in addition to the rearward rake. I did this by using the back stay to spring the mast towards the stern. This of course had implications for the shape of the mainsail at the luff. Hence the templating that I had to do when shaping the sails. My 1989 Endeavour has a fixed back stay as well as pairs of running back stays on either side. The fixed back stay is absent on your 1934 version which relies solely on the running back stays (a recipe for dismasting if you ask me!).
