Gentlegiant
Everything posted by Gentlegiant
  1. a photocopie of the plan x 3.714 give just the good scale for trace it on a 1.5mm plywood. It will take a copier with the possibilite of print the copie x 3.714 . I don't know if it 371%.
  2. If someone have the frame of the first and the second deck (22810-3).I am interesting . I search all the solutions.
  3. Hello I am forced to take a brake ,i do not have the plywood with the first and second deck ,i email to the seller and i wait for an answer,
  4. The frame are perfect with the keel but there are little curve in the other side ?
  5. I glue the frame at my best ,if i let 2 hours before glue another frame is that o.k.?
  6. Ulises O.K i have metal square and some spring clamps thank you this is really clear with the photo.
  7. i can glue the frame and fit all wen i put the lower deck very interesting Thanks
  8. I start to build the Bounty , i read all log that i find on the Bounty. I have a question right in the first step as you see in photos the false kell and the frames 4 to 10 are not right . I need to put the false keel and the frames all very nice at 90 degre ?
  9. Captain AL , if i understand you use three planks for the lenght of the hull , this is interesting.
  10. Tank you for the advise of matching the open ended planking , this is an other challenge too.
  11. Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ? ​
  12. Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ? ​
  13. Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ? ​
  14. Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ? ​
  15. Hello all the Bounty builders , i follow all your build log. I foud full good idea in all the different build log for building mine.Last week i check the instructions and the parts , and i have a question about the single planking with the 2mm thick walnut .Watt do you think off double planking with two kind off strip more thin ?
  16. Hello Mobbsie I have this plan but this is my first ship witout lazer cut wood .I see your wood on 1 November 2014 is it possible to have a list off that because i realy dont know watt and where command wood ? Thank You
  17. Hello Jack This is my first model and i know nothing about the wood . Can you give me the list of the wood you buy for make this model . (On the 2 January photos ) Thank You Gentlegiant
