Everything posted by CDW
One of the kit decal options is for a particular year in the life of this car when it was red. I wanted a red Ferrari instead of the black as shown on the box art. Due to complications of fit, I chose to resort back to the kit-supplied engine rather than the aftermarket one. I just won't have the time to fiddle with all the small mods needed to make the aftermarket engine fit this particular car. Maybe I can use it in a later model, Ferrari 250 GTO project. June is quickly approaching so I must get moving. Besides, I was looking at photos of this model built using all stock components and it looked very good. Color applied was Mr Surfacer 1500 pink, followed by Mr Color Super Italian Red.
Thanks Mike. Some of the newer kit releases like this one are coming in with fantastic decal sheets that replicate the 1:1 car and their livery. I'm 90% certain the 1:1 subject is body wrapped nowadays, so the decals are very much similar to the real car in that respect. In the old days gone by, all those graphics were hand painted but no more. The graphics are CAD drawn and painted, then printed out and applied to the car body just like decals. I've even seen videos of the application using heat guns, similar to the hair dryer technique that Dr Rob recommended I use. It worked like a charm. It was tedious work applying all those decals, but it gave a result I could have never achieved otherwise. The Salvinos Jr modern NASCAR kits come with unbelievably good decal sheets. The precolored plastic bodies don't even need painting, just the decals.
Honda RC166 by DocRob - FINISHED - Tamiya - 1/12 - multimedia
CDW replied to DocRob's topic in Non-ship/categorised builds
Beautiful, it looks amazing, Rob. Top shelf. -
I'll start with the engine. This is a 3D printed one from Texas 3D Customs. Very well detailed, much more so than the kit engine which is clunky, inaccurate, and outdated by more modern reproduction capability. Could I get by without it, yes, for sure. But I bit the hook and here it is. I plan on priming with a black primer then using a combination of acrylics, metalizer lacquers for dry brushing, detail paint the engine in the next steps.
In the photo, there is an acrylic paint marker shown. It came in a set of 24 colors from Amazon for less than $9, delivered. Since buying the set, they have come in handy many times for touching up or painting small parts rather than dragging out a jar of paint and a paint brush. For me, the fine tip gives better control for painting or touching up.
She's a beauty, a thoroughbred. -
It was a great idea using masking liquid to hold your spokes in place. I wrestled with them, finding the task of attaching the spoke nipples tedious at best. I can see where the masking fluid could have made the task more manageable. -
I started off using Tamiya Markfit strong as my decal solvent for the dash carbon fiber decals. Since then, have moved to Solvaset as there seemed to be some stubborn areas in the decals that needed to settle down, a stronger solution needed. There are no less than eight separate decal pieces that make up the dash and instrument clusters. The first full color decal was used on the spoiler. It seems to be setting up well with the Markfit strong solution. So far so good, but time consuming.
Your thoughts about the civil servant car are humorous. I can imagine how that could influence the way one looks at a particular car for a lifetime. I like your analysis of the thinner to paint/pigment ratio and agree the leveling thinner does just that, it helps to level the pigment and carrier for a smooth finish.
This particular model is an ocean of black, it's that way on the 1:1 car. With the interior now 90% built and painted (flat black), there is not a whole lot to see. Hopefully the plethora of decals will change that somewhat. if not, I may need to give it a little bit of help with some dry brushing in the cockpit area. But even the real car is very black as the photos I will attach can attest. All that carbon fiber gets replicated with decals from the sheet supplied in the kit. The real car: The model at this stage:
This is Tamiya lacquer, LP1 mixed 50-50 with Leveling Thinner 400 for the first three coats. For the last coat, I add more Leveling Thinner 400 to the 50-50 mix, so that it's more like a 60-40 mix, 60% being Leveling thinner. That's where the glass smooth finish comes from, that very last highly reduced coat.
