Bontie
  • Gender
  • Location
    Stilbaai, Western Cape, South Africa
1,269 profile views
  1. Hi Wimlich, I know you have built the Mayflower 10 years back but I was wandering if I could contact you for some advice?
  2. Is there anyone in the world that can help me to understand the references from the Mayflower wooden model bby constructo's instruction manual?
  3. Harrypsk, I would love to see the pictures on you building log. Speccialy as far as the pkanking is concerned but for some reason I cannot open any of the pictures?
  4. How long should I keep mohogany plank in boiling hot waterto bend propery?
  5. I bought the wooden model kit of the Mayflower (Constructo) years back. I want to "re-start" building it but I cannot find it the drawings that I got with it. Is their anyway anyone can help?
  6. Del I am in the starting stage of the same ship. I suppose you finished your build? If you do not mind helping please? I have to start the planking now. In your first post you mentioned the "I took the plank off, and made the bow solid, with a ‘sandwich’ of thin pine planks, then put the plank back" where did you put the pine planks exactly? I attach a pick of my build so far.
  7. I cannot thank you guys enough for the advice so far. Reading articles and buildlogs wrt filler blocks and done that on the bow (see attached pic) would you suggest that I fill the stern as well?
  8. Looking at the positions of the bulkheads and the advice I got earlier in the thread, I am not sure how to fix this? Should I shave the other bulkheads (green) to be shorter or should I just leave the gap (red) and hope for the best? Please experts help!?
  9. Bluto Thank you for the response. I will follow you advice. I did follow the link you provided and posted there but it seems to be at the same place where it was originaly posted? I'm a bit lost on this site. I will spend some time on it to brows the options.
  10. I bought the kit in 2008. This far I have: Glued the frames to the keelson Glued the decks in place I am now at the stage where I have to shape the ribs. I am not sure how much I must do this? How is the part that must be beveled measured? The instruction manual mention marking the the edge of the rib with a felt pen. I'm not sue how and by how much? I also, on advice, filled the front between the keelson and the front frame with soft wood to make planking easier. Did I do it right?
  11. I am building the Mayflower... since 2008... a few years back my wife said it looks like I won't ever finish it... now my son also joined the choir... suppose I've got to give it a go?
