Everything posted by Y.T.
Tired hearing of "pirating". Proof of pirating must be presented before accusing. In general this issue is the matter for legal courts. Has little to do with consumers.
If you do, buy it with standard Proxxon collets set to hold the tool. Do not get adjustable chuck as it is inaccurate. Also you may consider buying this contraption. This is very handy.
It is held by lowering and holding a drill quill. I find it extremely efficient. I have Sherline mill but would never do blocks on it even with a sensitive drilling attachment I have. It has about 5 thou runout on the 0.4 mm tool. My Proxxon setup is 1.5 thou runout. Sherline is for some more crude and metal work.
There is an adjustable stopper bolt. Look at my picture.
Pirated or not pirated by Chinese manufacturers, the plastic Unimat is for kids play. It is not for real work even with ship modelers.
I use this arrangement for all my micro drilling and milling needs as making small rigging blocks as small as 2.25 mm. it has perfect speed for drilling wood with micro milling bits up to 20,000 RPM. I highly recommend it. I use drills and mill bits as small as 0.3 mm diameter. By the way, what you see on this picture is a set up for making those rigging blocks 2.25 mm high.
Good 'Hobby Quality' Metal Lathes
Y.T. replied to tmj's topic in Modeling tools and Workshop Equipment
Do you mean ER collets? -
Congratulations! It looks hardly used and clean of corrosion. One issue I was having with mine like this is that the motor interferes with a work piece. I wish the motor would be separated off the lathe and mounted of a common board further back to be away from work piece. This however kills the advantage of lathe being compact. -
tmj. Here is private Toronto listing for Unimat 3. Platform is called Kijiji. Here people sell their own stuff. No taxes. No exposure to the government. Looks like a great offer with lots of accessories. https://www.kijiji.ca/v-power-tool/city-of-toronto/emco-unimat-3-lathes-milling-machines-and-accessories/1729699213 -
Repurposing Pool Cue Lathes?
Y.T. replied to Rich Sloop's topic in Modeling tools and Workshop Equipment
The way you describe it is exactly how I make the masts and spars. With exception of the note quoted above. I do not get it. For final rounding the sections of mast / spar with a sandpaper I hold one of the ends in electrical drill. I wrap that end with a masking tape quite a few turns so drill chuck does not damage the wood. -
I bought this attachment on eBay for something like $300 Canadian. Any Unimat parts are expensive. -
No. Thanks. I will keep it. About the motor the former owner said it is not after market. It’s a later improved version with 100% duty. It is one speed DC with brushes. -
Yes. At the end you will not be able to do all you want on Unimat as it is too small and will buy Sherline or whatever is larger you like. Unimat will sit collecting dust and reminding you that you spent $1000 in vain. -
If I were you, tmj, I would think again buying Unimat. As I said I own both Unimat DB/SL and Sherline with extended base. Both were purchased second hand locally through local equivalent of Craigs List. Now Unimat sits idle as Sherline can do any job that a Unimat can. I should have sold Unimat but somehow feel attached to it. -
It is not necessarily a bearing issue. Unimat I have has a pretty loud motor. Louder than Sherline. -
Speaking of collets for Sherline, I just purchased ER16 collet holder on AliExpress. Sherline uses Morse #1 cone. This holder costs CAD 16 with shipping. Set of ER16 collets from 1 mm to 13 mm I got for CAD 27. This is just a small fraction of what Sherline charges for their collets. And the ER collets also more useful than ones they sell to my opinion. -
I own Sherline lathe and Sherline mill. I also own Unimat lathe. This is all I will ever need for modeling. What is good about them? They are good. -
Wildmanden 1755 by Arthur Goulart
Y.T. replied to Arthur Goulart's topic in CAD and 3D Modelling/Drafting Plans with Software
I also enjoy how the planking was done at the bow. Looks like planks were cut out curved off the sheets of wood rather than force bending the straight ones. The planks lay out so naturally and almost perfectly parallel to waterline even at the bow.- 41 replies
- Wildmanden
- Turesen
These old model hulls in museums look like they were tainted to look as dark wood and lacquered. Is this correct observation? I am interested how these models were finished. May be they were not finished at all and collected and old look with time?- 41 replies
- Wildmanden
- Turesen
Loose Planks
Y.T. replied to Rich Sloop's topic in Building, Framing, Planking and plating a ships hull and deck
Glue it with thin CA as suggested. You can press plank in with the fingers but through the plastic bag. If gaps are present fill them in with wood filler or the saw dust mixed with PVA. Grind smooth with scrapers and sand paper. Repaint.
