mandolinut
Everything posted by mandolinut
  1. I am working on a few peripheral projects including the helicopter and the foredeck windlass. As I mentioned in an earlier post, I found a very detailed helicopter model in the same scale as Calypso with a lot of detail regarding the engine and cockpit. I felt the one piece molded clear plastic helicopter body/ engine (see photo) that came with the model kit fell short of matching the detail of all of the beautiful brass deck hardware. I will modify the rear end of this helicopter model to match Calypso's. I still have not attached the upper deck. Helicopter started. Needs painting with detail on the engine and instrument cluster. This is what comes with the kit. No interior cabin detail or engine detail.
  2. I had been putting off painting and installing the supporting columns for the upper deck until I was ready to attach the upper deck because the columns would appear to be fragile until the upper deck is installed. Gave the brass columns a light sanding and applied primer and then paint. Drilled holes in the decking and installed them. In the photo, the upper deck and wheelhouse and chimney are just sitting there (dry fit). I had to grind down the top off of a few of the brass columns to make them fit without raising the upper deck. Also adding black paint to the sides.
  3. I have been out of town for a while and was anxious to begin finishing the upper deck on Calypso. I will now put the supports in for the upper deck that come off of the lower cabins before attaching it.
  4. I added the previously built side rails today and began planking the upper deck. Used a black EXPO dry erase pen with a flat applicator, as I used on the main deck, to blacken the planks edges before gluing them down. This will take a few more days. Enjoying the journey.
  5. I am very happy with the high level of detail from the Billing Calypso regarding the numerous brass parts on the crane, wench, windless, portholes, and numerous other deck features. However, the helicopter falls short , lacking any detail which would be ok if there was no detail anywhere else. Thanks to fellow Calypso builder Don Nunnehi , I saw where he used the Bell oh-13 Sioux helicopter by Italeria. 1:48 scale as opposed to 1:45 scale of Calypso....close enough. This model has amazing detail in the cockpit and building the engine is a subproject within a subproject :0) There are many engine parts as you will see in this photo showing only some of the engine parts. I plan to use the cockpit and clear canopy and engine from this Italeria kit and then scratch build the rear body and tail section to match the Calypso Hughs 300 helicopter. Received the kit in the mail and started gathering engine parts. I will use the pontoons supplied by Billing to attach below the helicopter. Thanks again to Don for the idea. Here is a fun video of the engine build I came across:
  6. Today, I joined and glued the two upper deck sections. Planking over this entire structure will be next. Since this will be a static model, there is no need to have this deck removable, and I want the decking planks to run continuously without a joint where the two deck halves come together. I marked the reverse side of the upper decks for the future locations of various structures. ures
  7. Thanks for the nice words, Nirvana. I had time to work a bit more on putting together my wench assembly today. Feeling a bit like a watch maker at times with the variety of interesting brass parts. Once painted, I will add the four posts and the canopy. I added a small, curved wire to the electric motor and have it disappearing under the platform to simulate an electrical supply conduit. It has been fun working on the crane and wench, but I am now ready to get back to working on the ship.
  8. I gathered parts for the winch assembly today and began constructing. This should be fun. I also found an old "crab claw" clasp from some jewelry parts gifted to me. I believe this will make a nice hook for the mini sub crane. I had to remove part of the claw to make it work.
  9. Worked a bit more on my crane assembly today. Added the hydraulic pistons and a few extra hydraulic lines as seen in original photos. I felt more like a watch maker. This is good touch therapy for these 76-year-old hands. About halfway there for the crane. A project within a project. Love it.
  10. I finished adding the Micro Krystal Clear to the bow portholes in anticipation to gluing down the deck. The product works as advertised leaving a glass like porthole. Showing one of the portholes finished. Also showing two of the nose bulb observation portholes, one glazed and on not glazed. I will do the same for the decompression chamber. Also working on the crane which I believe is a rite of passage for any Calypso builder. Many parts that have to fit correctly. Here it is dry fitted. Need to paint the crane and then add a number of the pullies for the cable. I see the hull needs more paint. d
  11. I received my order of Micro Krystal Klear and tried it out on one of the forward portholes. Backed up the porthole with clear acetate taped down on the inside. As described, it looks like milk when applied (see photo) but dries clear and looks quite good. I will now do the other portholes including those portholes for the decompression chamber and viewing ports on the front bulb. Also working on assembling the crane which is interesting.
  12. Back on the workbench today gathering parts for the aft crane that use to launch the mini sub. Looking at the instructions and finding the various parts is much like doing a jigsaw puzzle where you look through 500 pieces to find the piece or pieces you are looking for. Note to future builders: the upper crane assembly (2 parts) has a long rectangular plastic spacer in between them. This unfortunately does not show up in the plans. See photo. I then glued the three pieces together and drilled out a number of holes in the various areas where a small wire will pass through and act as an axle for the various pulleys.
  13. Calypso got her "wings" today. The pilot house curved fairings are a very nice and distinguishing feature, so once again, my ship is starting to look more like Calypso. Before soaking and bending the curved panels, I painted what would become the inside which would be very difficult to do once they were attached. I also found a reference photo of the pilot house showing some triangular supports under the ledge of the front windows, so I added that touch. Still needs lots of sanding, filling and painting to do everywhere but now I have something to work with.
  14. In anticipation of gluing down the forward deck, I added basswood strips along the upper edge to have more of a gluing surface area for the deck. Also added some cross pieces for the same reason. Without these wood strips there would be very little ABS to glue the deck down. Also painted and added doors (not included) for what would be an entrance to the forward cabins. I still need to add clear liquid plastic to the forward port holes before attaching the deck.
  15. Thankyou Alan. I am warming up for the foredeck and lower cabin roof tops.
  16. I had fun adding deck planking to the wheelhouse roof and the upper cabin roof today. At this point they are not glued down. Feeling good as the ship is starting to look more like Calypso.
  17. Making some progress on Calypso. Really enjoying this journey. Added some grab rails to the sides of the upper and lower cabins port and starboard and also to the steps of the wheelhouse. Also added flooring and paint to the interior of the wheelhouse. Trying to decide how much detail to add to the interior. It would be very hard to see. Painted the steps leading to the wheelhouse before gluing on the outer fairing. Started working on the ship's funnel which I usually call the smokestack. Everything still needs a lot of clean up, sanding and more paint.
  18. I have decided to plank the entire foredeck and cabin deck and placing the structures on top rather than cut all of the deck planking around the fixed surface structures. I am therefore anticipating transferring the graphics which are laser engraved on the top surface showing the placement of so many structures onto the bottom (backside) so I know where everything should be placed once the graphics are covered with planking. Same for the roof of the pilot house. I also began building the stairway to the pilothouses and the related supports. Now to add the middle step and front fairing.
  19. The roof tops and cabins are just sitting in place, not glued. I 've been working on priming, painting and sanding the wheelhouse and cabin structure behind it. Also added the molded plastic window details to the wheelhouse. I see from this photo I need to do additional sanding around the roof of the wheelhouse and cabins where I added trim to encircle the deck planking yet to be added. Also needs some filing inside some of the wheelhouse windows.
  20. Here is a link. They were "Bud Nosen" from Midwest. Bud Nosen Basswood Strips, 1/16" x 1/4", 50-Pack I suggest roughing up (sanding) the ABS plastic hull to prepare it for glueing the wood strips. I used Gorilla Super glue from the local home store which worked great. Gorilla Glue Super Glue 15g Bottle Net Content Quantity 1 - Walmart.com I used my fingers to hold the wood in place until the glue set up, about 15 seconds. On a few of the strips near the deck, I placed the wood strips in boiling water (cookie sheet) and let them dry in place while mechanically clamped over the curved hull. As you get closer to the water line there is less curve and no need to prebend. Hope this helps.
  21. Had fun today building the wheelhouse. Getting the windows all lined up was a little challenging which is a good thing. Also drilled and added the bolt heads on the bow. Having a pair of calipers was helpful for spacing the bolts. Also made the cradle for the decompression chamber.
  22. I feel a bit embarrassed. As I looked at the parts list in various languages I stopped at the bottom of the GB (English). A few pages later the list picked up again with the higher numbers so problem mentioned above is resolved. While in the window and door mode, constructed the upper cabins, reinforced in the corners. Also started work on the decompression chamber by adding square scraps of wood to the top surface as shown in the plans. Bent some wire for the grab bars and attached. Also added handles for the entry hatch as shown in the plans. Finished with a coat of primer. I began sorting out numerous parts for the aft crane.
  23. "Thanks for sharing your experience." Thank you for your comment bowwild.
  24. Have any of you previous Calypso builders had a hard time identifying part numbers and therefore parts in the pictorial directions? I was looking at the crane parts today and could not identify many of the parts based on the numbers shown. I see part numbers like 735 but the index in the back of the instructions have no such part number and many other part numbers do not show up. Is there a complete parts list that may have not been packed in my kit? Any advice would be appreciated. Patrick
  25. Hi Don, I am starting to build the crane and other deck hardware. I have a big question and favor to ask. The plans show part numbers for the various crane parts. Some are obvious like the plastic molded parts. Others, I have no idea. In the kit you had, was there a complete parts list matching numbers from the instructions with various parts? All I have is the back of the instruction booklet with a very partial list with no numbers to match the numbers in the plans. Thank you. Patrick
