About SaltyDog
Le Cerf c.1779 by SaltyDog - Dusek - 1:72
catopower reacted to a post in a topic:
brunnels reacted to a post in a topic:
I glued the deck down using Titebond Original (PVA wood glue) applied to the veneer and deck and then left to dry. Then the two were placed together and heat was applied. This method is described on various posts on this site as well as videos that describe applying wood veneer to substrates. My observations; the veneer curled width wise when drying producing some splits/separations (the veneer was quite thin), the width of the veneer increased because of the moisture in the glue, I trimmed it against the bulwarks with a scalpel. The edge of the veneer was mostly covered by the waterways. The other thing was that the clothes iron I had (the one the Admiral was willing to let me use) was too wide to iron the deck, so I used my plank bending iron. A miniature hobby iron would be an ideal future purchase.
My latest project is the French cutter Le CERF building the Dusek kit.The quality of the wood, veneers, drawings and instructions is excellent! So far I've assembled the keel and bulkheads, done some infill between bulkheads with balsa and started some of the planking in the area of the deck. The kit receives a complete layer of planks in the clinker fashion, a second layer of laser cut veneer carvel style planks will be added to the lower portion of the hull.
SaltyDog reacted to a post in a topic:
Berbice 1780 by SaltyDog - Shipyard - 1:72 - CARD
Thank you both for the suggestions regarding the copper tape. I'll need to get a supply of one more item, patience!
Finished with coppering the hull. It's a little too shiny for my taste, so I 'm thinking of ways to weather it a little bit. Finished the transom railing. The posts are these really malleable pieces of cardboard soonce attaching the them to the stern I applied CA to harden them and them attached the two pieces of top rail.
